Old 04-21-2018, 11:39 AM   #1
Trailer brake adjustment question
We have a new trailer with just over 800 miles on it. It was a new 2017 that sat on the dealer lot most of the year and we purchased it in early 2018. I've read that you should adjust the brakes after the first couple of trips. I've watched the You Tube videos and it appears pretty easy. My dumb question is this....do you turn the star nut up or down to increase drag? Or is it opposite depending on which side of the trailer you're on? I'm sure I could figure it out once I get started, but want to spend as little time as possible underneath a 3 ton trailer and get it done quickly if I can! Thanks.
Brian and Tracy
2017 Flagstaff 26FKWS
2014 GMC Sierra 1500 5.3
Smiletwice is offline   Reply With Quote
Old 04-21-2018, 12:00 PM   #2
Have you read the paperwork that came with your TT. My brakes auto adjust when backing up. Check your paperwork.
2011 Traverse LT, 3.6L, FWD
Old 04-21-2018, 12:26 PM   #3
I find that the most backup self-adjustment systems do not work well as advertised and you can do a better job adjusting the brakes yourself.
Drum brakes usually can be only adjusted one way as there is usually, but not always, a ratchet mechanism on the adjustment that only allows one way rotation.
Be very methodical and use the "spoon" tool or screw driver judiciously and spin the wheel to ensure that the brake isn't dragging. I prefer just a tiny big of drag but not to much that it builds up heat and can cause tire issues from heat, decreased fuel economy, and trailer brake wear.
If you overtighten, remove the tire and hub and lift the ratchet so the brake adjustment can be loosened.
Skyliner is offline   Reply With Quote
Old 04-21-2018, 01:04 PM   #4
Jack the unit up by the frame to get the tires off the ground. Turn the tire by hand, if you donít hear the shoes rubbing they can use adjustment. Most are adjusted by turning the star wheel up from the bottom, mine were, both sides were the same. If you go the wrong way just reverse what you did. You will know after a few clicks. Tighten so you can barely turn spin the tire then back off till you just hear the pads rubbing.
Nascon is offline   Reply With Quote
Old 04-21-2018, 01:41 PM   #5
Usually the adjustment screws are right hand thread on one side, left hand thread on the other. You turn the notched wheel in the direction you were rolling it toward the center of the trailer. They should move easily in only one direction without releasing the pawl.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 04-21-2018, 02:17 PM   #6
Retired Member
rmwmiata's Avatar
Also if you overtighten you can push on the ratchet through the opening with screwdriver just enough to reverse star wheel. Will not have to remove wheel and drum if lucky.
Pam and Murry Wilbanks
2018 SIERRA 377 FLIK
2018 Ram Laramie 3500 DRW
rmwmiata is offline   Reply With Quote
Old 04-21-2018, 02:56 PM   #7
Don
Why does my RV have 2 adjusting holes in backing plate?
This is good information that I needed. I have a FR Signature Ultra Lite 5th wheel and the brake backing plates have 2 adjustment holes in each plate. Any Idea what the two slots are for. Normally there is only one for adjustment of the brakes.
Sandy12345 is offline   Reply With Quote
Old 04-21-2018, 03:42 PM   #8
Send a message via MSN to Tiggerdad
When I adjust I use the following motions concerning the adjusting tool.
Down and out
Up and in.
"IN" being loosen
"Down" is pushing the shoes out to tighten and increase drag.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 04-22-2018, 03:26 AM   #9
DouglasReid's Avatar
A universal plate that can be used on either side without the necessity to keep 2 sets in stock.
The adjusting wheel mechanism is the only difference in one side to the other and this way the backing plate will line up with both right hand and left hand adjustment systems.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 04-22-2018, 10:25 AM   #10
My experience is that few trailers come with self adjusters. Even if they do, they probably don't work well enough to keep the adjustment correct. To properly adjust you have to remember you're on the back side, so up is out, down is in, but if you've gone out to far the shoes may not spring back properly so go lightly. You should hear the shoes just start to drag while spinning the wheel. That's plenty. Too much pressure and the brakes will heat up and drag. Of course you should have taken the drums off, replaced the rear seals, and repacked your bearings prior to this adjustment. Just saying.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
trailer
