Old 08-23-2014, 12:41 PM   #21
below a link to the owner's manual of the P2:
http://www.tekonsha.com/content/down...ion/N90885.pdf
and now that you mention it: it might even be b (boost?) instead of a 6
2002 Sandpiper Sport T28
1996 Dodge Cummins
Iceman_RNR is offline   Reply With Quote
Old 08-23-2014, 12:57 PM   #22
BigTJohn's Avatar
How long has it been (in miles) since you have done a brake adj on the trailer. Worn brake pads will cause the need for an adj of the controller. Once I get to a higher number (RAM integrated controller) say 8.5-9.5 or so, I do a brake adj and then I'm back to 5-6 on the controller. Just a thought.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 08-23-2014, 03:53 PM   #23
Originally Posted by DDC View Post
Is your truck not still covered by warranty? Also make sure you are able to install an after market controller I seem to remember reading something about this because the one that comes installed is hard wired.
It would be insanity to run an aftermarket brake controller on a vehicle with a working IBC.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 08-24-2014, 01:40 PM   #24
Originally Posted by jrs_diesel View Post
I put a Maxbrake on my truck. It tee's into one of the brake lines from the master cylinder with a pressure sensor. Calibrated it to the truck and was good to go.
My trailer does exactly what the truck does when I push the brake pedal. It's very nice not having to fiddle with the controller as I tow. I just drive.
X2!
2011 8314 BSS Rockwood Signature Ultralite
2005 Dodge Ram 2500 Quad-cab SLT
Makoto is offline   Reply With Quote
Old 08-24-2014, 01:58 PM   #25
FandRChambers's Avatar
No I have a 2002....it does not have a factory brake controller. I bought the plug for my truck and plugged directly in...I am running it on b3...guess it's doing what it's suppose to...my iold controller I felt a lot of pull back from the trailer this one doesn't. ...that's what made me post the question
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
FandRChambers is offline   Reply With Quote
Old 08-24-2014, 01:59 PM   #26
Oh and my unit is a 2013 so no I haven't adjusted the brakes
Fred & Teresa
2002 EZGO Golf Cart
Old 08-24-2014, 02:14 PM   #27
B3 is the boost level. You still need to set up the voltage that the trailer sees. This is setup buy turning the wheel on the left side of the controller. When you move the leaver on the bottom of the unit all the. Watch to the left the max voltage will show up on the display. This voltage has to be setup for the controller to work right.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
Happy Vibe is offline   Reply With Quote
brake control, controller, trailer, brakes
