Old 05-31-2015, 05:37 PM   #1
trailer brake issue
We just purchased a 2015 Wildwood X-lite 262BHXL. The trailer brakes are not functioning when hooked up to my tow rig. If I pull the emergency trailer brake pin the brakes lock up immediately. Where could my issue be? I have hooked up another vehicle that has electric brake wired up and get the same behavior out of the trailer brakes not working.
Of course its sunday and the dealership is closed, I have a camping trip this coming weekend. anything I can do myself to resolve this?
Primary Tow: 2007 F250 CC 6.0 diesel 4wd
Tried
2015 FR Wildwood X-Lite 262BHXL
2007 F250 4wd CC SB 6.0 Diesel
5LowesOR is offline   Reply With Quote
Old 05-31-2015, 05:47 PM   #2
Ford Idaho's Avatar
Check for power to the TV's pigtail connector, if no power check TV for popped fuse.
ummm no upon reflection I think it might be a connector wire problem.
Old 05-31-2015, 05:48 PM   #3
brookstone345sa's Avatar
If you did not tow with this truck before, there is a fuse required under the hood, usually square box. Check owners manual for location of trailer tow fuse. It's usually a 20-30 amp.
When you pulling breakaway switch, it gets it's power from camper battery
Also, make sure the 7 pin plug is wired correctly
brookstone345sa is offline   Reply With Quote
Old 05-31-2015, 05:50 PM   #4
Broadway Joe's Avatar
Do you have a brake controller, either integral or add on unit?
Broadway Joe is offline   Reply With Quote
Old 05-31-2015, 06:07 PM   #5
The truck has the stock ford trailer brake setup. adjusting the gain from 6 to 10 gave very minimal change to how the tire reacted with it jacked up and spinning by hand.
Old 05-31-2015, 06:11 PM   #6
I opened the junction box under the frame where the trailer cable runs back to and the trailer brakes connect up. all the wires are crimped by the factory together. everything appears to be connected up correctly.
Old 05-31-2015, 06:19 PM   #7
Flybob's Avatar
Have someone hit the brakes and check voltage at the Bargman connector on the TV. Check the use box as mentioned. Many times the TV comes to ready, but the fuse is not installed. Saves the Mfg $1.00
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-31-2015, 06:44 PM   #8
what voltage should I see?
Old 05-31-2015, 06:56 PM   #9
I read an article that said the early ford brake controller would only give a vary small voltage out if the truck was not moving. Some commercial guys were getting tickets for non operating trailer breaks. Not sure if this still applies.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-31-2015, 07:11 PM   #10
fonzie's Avatar
If your brake controller is set to maximum you should see 10 volts and above at connector, make sure engine is running.....(that is what I see on my unit)
Fonzie
trailer, brakes
