Old 05-31-2011, 07:18 PM   #1
Trailer Brakes
Took our new trailer out for the third trip this past weekend. When I was getting started I had turned the brake controller up a couple since I was in Atlanta stop and go traffic and had the trailer actually fully loaded like it will be going forward. When I braked the TV was pulled to the left. It continued so I turned the controller back down.
Did I have the controller turned too high or is there something wrong with the trailer brakes, the trailer brakes did not lock up.
If something with trailer brakes before need to have corrected before our 2 week trip to Yellowstone and Glacier.
Paul & Karen and the 2 Little ones in tow.
2007 Nissan Armada LE
2012 Wildwood 26BH XLite
20 Nights campled in 2011.
25 Nights Planned for 2012!
pandkm is offline   Reply With Quote
Old 05-31-2011, 07:28 PM   #2
sherdep's Avatar
what brake controller are you using?
it doesnt pull when you have it set to the lower setting does it?
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-31-2011, 09:33 PM   #3
It is a Husky Escort.
It does not pull at the lower settings.
Old 05-31-2011, 09:43 PM   #4
sherdep's Avatar
Let me say this - I am no trailer brake expert by no means
Might be worth a shot to call and ask about the controller since you have a 2012 Trailer - my guess would be in the controller
Was the controller bought new?
Possible other cause - Could have a brake out of adjustment (too tight) and you really only notice it when the brakes are applied harder then normal.
Old 05-31-2011, 09:45 PM   #5
Herk7769's Avatar
OK, does it pull on the truck when you brake? or left or right.
If it feels like the camper is "tugging" on the truck when you brake it is too high. If it pushes the truck it is too low. If you don't notice the camper braking it is just right.
If it pulls the truck left or right, one or more of your brakes are not working and they should be checked.
HAM CALLSIGN - KC3FFW
Old 05-31-2011, 10:13 PM   #6
Try adjusting the brakes first. If you do not know how to do it, maybe it is time to learn as this is at least a yearly maintenance job.
Old 05-31-2011, 10:15 PM   #7
Agree with Herk. Should be even at any setting. May have a brake on one axle not wired right/not working. Take it down a dirt stretch, turn the controller all the way up, and use the manual control to activate the brakes and see if all 4 wheel lock. DO this at a slow speed, 10mph or so.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-31-2011, 11:17 PM   #8
controller was purchased from the dealer when we purchased the trailer.
Just really feel it pull the tv to the left, do not really feel a tug
Since it is still under warranty I will try and see if the dealer can get it in and out before our trip. Other wise guess it is time to learn how to inspect and adjust them myself.
Thanks everyone for their input.
Old 06-01-2011, 08:24 AM   #9
M109Rrider's Avatar
It's not the controller. The controller controls all brakes at the same time evenly. How far did you pull it? If my old trailer would sit for a while the brakes sometimes would work funky. Think it had to do with corrosion on the electro magnet surface and brake surface of the brake drum. After a couple miles they would be fine But definitely adjust the brakes and make sure all the wires to the electro magnets are connected
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 06-01-2011, 08:44 AM   #10
Wanna Be Camper
SaskCampers's Avatar
Ditto,
Pin 2 in the plug is the only brake wire coming from the TV so if it is braking then the circuit is good, must be one of the brakes or a bad connection to a brake and it is not braking as hard. My flat deck had loose connections and it did not brake as hard as it should, redid all the connections and all worked as advertised. You can always take it on a deserted road and bring it up to abt 30mph and use the manual override as hard as possible and see if it still pulls just to verify the issue.
John & Deb
2011 Flagstaff V-Lite 30WRLS
brakes
