Old 07-16-2016, 10:56 PM   #11
Usually Confused Member
emm-dee's Avatar
Originally Posted by Filterman View Post
Just a note, you can replace all four wheel ends with fully loaded backing plates and self adjusting drum brakes for $57.95 an end from etrailer. Just take out the five bolts, cut and resplice the wires and your ready to go. Not discouraging the disc brake idea just putting the cost in perspective.
Good Luck
Triple that number for quality brakes and eight stud drums on 7,000+ pound axles.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-17-2016, 01:33 PM   #12
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by mfMcFroggierPod View Post
Has anyone upgraded/or have disk brakes on there trailer? Are they worth the $2500.00 conversion or perform better?
There's an article in this month's "Trailer Life" that covers this conversion. You'd have to be towing a heavy trailer to make it worthwhile, IMHO.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 07-19-2016, 10:04 AM   #13
SilhouettePenny's Avatar
Good Luck
I concur, eTrailer.com will ship in just 2 days. If you can remove, inspect and regrease your own bearings, the next logical step is to remove the brake backing plate (5 bolts on mine) and snip two wires. Adjusting them after installation seems to be the time consuming task. Shoot 'em with a thermal gun after exiting at the interstate rest area, brake spoon down to tighten & up to loosen.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2016 - 43
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 07-20-2016, 09:33 PM   #14
duradiesel's Avatar
I just replaced all 4 brake assemblies [ backing plates , shoes & magnets ] for $270 . drums were ok. I also replaced 4 bearings. Replaced all the spring hangers with the the greasable ones for $160 . I could not believe how bad the spring hangers were worn.
2006 GMC Duramax Extcab LB
2012 Wildcat Sterling 32RL
duradiesel is offline   Reply With Quote
Old 07-20-2016, 09:39 PM   #15
Who Dares, Wins
doc73's Avatar
I would think you would need to tow a lot as well to keep them from rusting up. Used to fight that issue on my jeep when I let it sit for a while.
Sent from my Samsung Galaxy S7
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
brakes, trailer
