Old 07-15-2016, 10:26 PM   #1
Trailer Brakes: disk vs drum
Has anyone upgraded/or have disk brakes on there trailer? Are they worth the $2500.00 conversion or perform better?
mfMcFroggierPod is offline   Reply With Quote
Old 07-15-2016, 10:37 PM   #2
Suggest you do a forum search for disc brakes. A few people have replaced drums with discs. Vast improvement, fi they are to be believed. Worth $2500?? That's up to you.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 07-15-2016, 10:40 PM   #3
Usually Confused Member
emm-dee's Avatar
Had the conversion done on our horse trailer (16k gooseneck) for around $1,700. Worth every penny.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-16-2016, 12:12 AM   #4
I've never had a problem locking up my electric drum brakes on any of my campers. I say, if it isn't broke, don't fix it. $2,500 would get you a decent solar system (self-installed) which I rather have than disc brakes. But then again, I'm not towing horses.
Skyliner is offline   Reply With Quote
Old 07-16-2016, 05:58 AM   #5
emm-dee's Avatar
I should have given more info. All four brakes needed complete replacement at a cost of almost $1,000 so the extra cost wasn't that bad. The biggest advantage of the disc system was how much smoother the it system was and never needing adjustments again.
Old 07-16-2016, 01:40 PM   #6
I guess disc brakes are one of those things that you don't know you needed until you get them.
This link has good info on them. Since I do my own work, I'm thinking that cost would be lower than paying someone to do it. I'll have to put disc brakes on my dream list.
Trailer Disc Brake Conversion - Electric Over Hydraulic Disc Brakes
Old 07-16-2016, 01:54 PM   #7
bscottroberts's Avatar
I went to electric over hydraulic disc brakes. Did the work myself. Trailer weighs around 16K. I spent $1500 on all the parts. Definitely well worth it. I could never lock up my drums. With the disc brakes I had to turn down my brake controller to 60%. And it brakes harder than ever. Will never have a heavy trailer again without discs.
2006 34FK Work and Play
2016 Chevrolet 3500 Duramax DRW
bscottroberts is offline   Reply With Quote
Old 07-16-2016, 03:07 PM   #8
Talking
Best 3000 dollars I ever spent. I would not buy an upgrade 5th wheel because it did not have disc brakes. Once you tow a rv with disc brakes and see how much better it stops as they say you will never go back.....
Bob Vaughn is offline   Reply With Quote
Old 07-16-2016, 09:19 PM   #9
Disc Brakes are clearly superior to Drum Brakes in almost all situations, especially when the vehicle is subject to frequent hard applications of braking force from high speed. However, this situation does not necessarily apply to the typical RV towing environment. Most trailers are not towed at high speed, or are subject to numerous, repeated high speed stopping situations, as are race cars and high performance sports cars.
If your trailer has come equipped with drum brakes, I would recommend that you simply keep the braking system in top condition with periodic inspections and maintenance. If you plan to keep the same trailer for more than 10 more years after your first purchase, then the switch to disc brakes might make sense.
Most important: Keep the tires and brakes of your tow vehicle in top shape, and make sure your trailer tires are properly inflated, lug nuts are tight, and all is well.
Jakie-Boy is offline   Reply With Quote
Old 07-16-2016, 09:26 PM   #10
Just a note, you can replace all four wheel ends with fully loaded backing plates and self adjusting drum brakes for $57.95 an end from etrailer. Just take out the five bolts, cut and resplice the wires and your ready to go. Not discouraging the disc brake idea just putting the cost in perspective.
Good Luck
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags.
2011 28RKS Wildcat. Yamaha 3000iseb Generator.
2013 22 nights.2014 57 nights.2015 116 nights +14300KM
2016. 96 nights
Filterman is online now   Reply With Quote
brakes, trailer
