06-23-2015, 08:18 AM
#21
Originally Posted by Vern
This is an interesting topic to me, and all the more so as I approach time for replacing the factory tires on my TT. My impression in speaking with tire stores is that they will fight you on this. On three separate occasions while purchasing auto tires (at three different shops), I've asked about this in conversation with the person I was working with and was told they never balance trailer tires. This has now occurred at a small, locally owned shop, at a Discount Tire, and at a WalMart.
It is normal, but I've never had or heard of any shop refusing to balance them.
06-23-2015, 10:52 AM
#22
they won't refuse but they look at you like you're nuts when you ask about it.."NObody balances trailer tires! It's a waste of your money" is what they say.
So tomorrow I'm wasting my money! LOL
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
06-23-2015, 01:00 PM
#23
When I bought my last trailer tires they assumed I wanted them balanced
and I did.
I did manage to talk them down $20 on the total which was already price matched to an online tire store.
I figure I'm rolling them in off the trailer.
They don't have to jack a vehicle.
They don't have to do the "free wheel alignment check"
They don't have to remove/replace 4 wheels on the axles.
I should get a discount over 4 tires on a car which does get all the above.
06-23-2015, 01:08 PM
#24
IMO they are trying to keep the end-user cost down... but I insist that my RV TIRES ARE BALANCED
2014 Shamrock 183
06-23-2015, 01:12 PM
#25
Just had new Maxxis installed and balanced. I mean why not? Tires cost $850.00 balance around $40.00. My thoughts are a tire is a tire so if I can cut down on any amount of shimmy or shake especially on my 5r it's a positive........... Just my thought.......
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
06-23-2015, 01:17 PM
#26
balanced tires
Yes I would balance the TT tires. And would also check the axles for alinement
going down the road over bumps, curbs, pot holes. etc. Yes balance tires.
06-23-2015, 01:28 PM
#27
tires on trailers
Normaly you don't need to balance trailer tires like construction trailers etc. But camper tires should be Balanced.
06-23-2015, 01:35 PM
#28
Remember in most cases your trailer tires are spinning at a higher RPM than your TV tires. Even if you replace your trailer tires long before they wear out, you save a lot of wear and tear on the trailer with balanced tires. It is easy to to more damage to the TT with out of balanced tires than it costs to balance them.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
06-23-2015, 01:50 PM
#29
Alleged curmudgeon
Makes sense to me...
I'll follow that approach.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
06-23-2015, 02:11 PM
#30
For me it is more a question of how much damage you are doing to your tire than how much the trailer is shaking. If you have ever seen a car with an unbalanced tire, that tire is taking one heck of a beating as it is bounced up and down. I have to think that would cause the tire to heat up more than if it was balanced. If I look at how much weight they had to use on my tires, there had to be a lot of bouncing before they were balanced.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
06-29-2015, 11:08 PM
#31
I had my balanced and installed metal tire valve stems. You need the metal valve stems to use the TPMS system.
