Old 02-26-2016, 12:56 AM   #21
CaptnJohn's Avatar
Originally Posted by TURBS View Post
Gary says propane weight and battery weight is absolutely not figured into the uvw sticker.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
That is what I have been told several times. The propane tanks are shipped empty and their weight is included on the sticker. The dealer adds propane and the battery is also dealer added... just as the toppers mentioned earlier. There may be some residual propane as builders generally test for leaks.
Old 02-26-2016, 01:43 AM   #22
JohnF's Avatar
From the current Cedar Creek brochure.
Each Forest River RV is weighed at the manufacturing facility prior to shipping. A label identifying the unloaded vehicle weight of the actual unit and the cargo carrying capacity is applied to every Forest River RV prior to leaving our facilities.
UVW (Unloaded Vehicle Weight)* – is the typical weight of the unit as manufactured at the factory. It includes all weight at the unit’s axle(s) and tongue or pin and LP Gas. The UVW does not include cargo, fresh potable water, additional optional equipment or dealer installed accessories.
*Estimated Average based on standard build optional equipment.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 02-28-2016, 05:38 PM   #23
Too Tall's Avatar
So, wouldn't the most critical weight be the weight on the axles (and tires) since the truck is carrying a portion of the camper weight? I'm more worried about overloading tires and axle and less about tongue weight. I don't plan on going over the GVWR, just trying to see if I am benefiting by transfer more load forward to the tongue and truck? Just concerned after reading about these China tires.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 02-28-2016, 06:38 PM   #24
Blackhat6mike's Avatar
My user manual says the propane tanks [2x30lb] and one battery are included in the UVW out the door. They are part of the figured 7,880 lbs as built. Don't know about other units, just my Aviator. It list 3,320 lbs as CCC for a total of 11,200 GAVW.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-02-2016, 03:13 PM   #25
CWSWine's Avatar
Copied from Forest River Website...
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 03-02-2016, 09:31 PM   #26
CaptnJohn's Avatar
"*Estimated Average based on standard build optional equipment." So,,, what is included in standard build optional equipment? 1st I heard that.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 03-02-2016, 09:50 PM   #27
Who Dares, Wins
doc73's Avatar
I'm guessing that is the part someone said is just a weight based off one trailer getting weighted from the same line. A SWAG....
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 03-02-2016, 10:20 PM   #28
CaptnJohn's Avatar
Smile
So ~~ if they weighed mine with 2 ACs, auto-level, and more those with the only option of 1 AC would get the same weight or the buyer of 1 like mine gets the lower weight. As the advertised weights rarely change ~~ few can be correct, EVER.
Old 03-03-2016, 12:22 AM   #29
Bluepill's Avatar
I made up this chart for reference on my camper:
CAMPER WEIGHTS AND BALANCE
TONGUE WT.
BASE WITH SPARE; NO PROPANE BOTTLES OR BATTERY 284#
BASE AFTER REAR HITCH INSTALLED 242#
ADD BATTERY 276#
ADD CARRIER IN REAR 215#
CARRIER, M/CYCLE, BATTERY 70#
ABOVE + GENNY, 2 PROPANE & 5 GAL. SPARE FUEL 315#***
***CORRECT TONGUE WT. WITH NO OR BALANCED CARGO
TOTAL WT.
DRY WEIGHT AS BUILT 2264#
WITH HITCH INSTALLED (76#) 2340#
ADD BATTERY (35#) 2375#
ADD 2 PROPANE (70#) 2445#
ADD CARRIER & MCYCLE (350#) 2795#
ADD GENERATOR (150# W/GAS) 2945#
CARGO CAP. = (980 LESS ABOVE) 300#
PROPANE FULL TANK (EA.) = 35# SPARE = 30# FULL H20 = 167#
Formatting from MS WORD didn't come through, but you can get the idea.
I installed a permanent rear hitch receiver to carry my motorcycle, and a generator on the front frame.
trailer, weight
