Old 05-19-2019, 01:22 PM   #1
Transmission downshifts on downhill braking
First of all, this problem occurs with TOW HAUL mode OFF
I have a 2019 Forrester on a 2018 E450 chassis. We live in British Columbia so it is just about all mountains. We recently did a trip across the province and ran into lots of long downhill runs usually 8% for over 5Km, some over 10Km..
The problem is that when freewheeling down the start of the slope the transmission wants to downshift every time the brakes are applied, as if it was in tow haul. On an 8% slope you hit 90KPH fairly quickly, so applying he brakes makes it shift down and the RPM jumps to about 3000. The speed starts to build up again so a second application of brakes is requires, the trans shifts down again and you almost hit 4000rpm. Your speed is still about 90kph and if for some reason you need to touch the brakes again, like a corner or a slow truck crawling down the hill, the f---ing trans will shift down again and the thing pegs to over 5000rpm. The only thing to do is to stand on the brakes and bring your speed down to under 40kph and hope no one rear ends you.
On a long 6% slope the terminal velocity of our Forrester 2291SF is about 95KPH, so as long as it is a modern highway it's not a problem but the 8% slopes it's somewhere over 120, so there is no avoiding the transmission trying to blow the engine up.
Has anyone else found this issue with the new Ford 6 speed transmissions. Our last motorhome was a 2006 and did not do this.
Mike Stanlake
Mstanlake is offline   Reply With Quote
Old 05-19-2019, 01:58 PM   #2
Mr. Dan's Avatar
I think if you study Ford users manuals, you’ll find that to be a feature not a failure. My 2014 GMC gasser 6-speed does it like an exhaust brake to save brakes.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 0
Old 05-19-2019, 02:02 PM   #3
NMWildcat's Avatar
Seems like most vehicles do this now. Sometimes I let it do it's thing (down shift on brake application), and sometimes I shift manually to avoid that.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 05-19-2019, 02:26 PM   #4
Don’t mind saving brakes but not at the expense of twisting that V10 at 5500rpm for 5 minutes to the bottom of the Salmo-Creston Skyway,
Old 05-19-2019, 02:31 PM   #5
Mr. Dan's Avatar
Originally Posted by Mstanlake View Post
Donít mind saving brakes but not at the expense of twisting that V10 at 5500rpm for 5 minutes to the bottom of the Salmo-Creston Skyway,
Check your manual and see if you can turn the feature off.
Old 05-19-2019, 02:38 PM   #6
Chuck_S's Avatar
Perfectly normal and something I appreciate on down grades, especially 8% grades. My 2017 Expedition EcoBoost does this in every day driving. Will not "free wheel" (which is unsafe anyway).
Not sure what computer modules your chassis has. Look in the truck (not RV) forums for what can be altered with Forscan (software) and your laptop.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 05-19-2019, 02:58 PM   #7
A32Deuce's Avatar
Next time manually put it in a lower gear to start down hill, then when you hit the brakes it won't down shift lower. Just did this earlier this month on RT 30 east in Pa. Also had a car trailer attached. 8 mile down hill.
A32Deuce is online now   Reply With Quote
Old 05-19-2019, 03:06 PM   #8
You think the engine computer is going to downshift to the point of damage? Bottom line, it's made to scream. Don't sweat it.
aeblank is online now   Reply With Quote
Old 05-20-2019, 01:06 PM   #9
Mike Stanlake
Are you sure you have Tow/Haul OFF (dash light is off)? What you are describing is normal for Tow/Haul ON. Downshifting when you touch the brakes with Tow/Haul OFF seems to be wrong. As others have said, check your manual. Maybe Ford changed the programming with your later model compared to how my 2010 E450 Tow/Haul works.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 05-20-2019, 02:38 PM   #10
BobHanke's Avatar
Might make sure you are not using cruise control going downhill as that can cause what you are describing.
"Lurch" = Georgetown 2011 330TS
Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = NaNa & NiuNiu
BobHanke is offline   Reply With Quote
