Old 04-03-2016, 07:19 PM   #1
Trying to Decide on Wet Bolts
I have been reading tons of info on suspension wet bolt setups and associated equalizers. Is there an advantage to only installing wet bolts without replacing the equalizer? My TT has a spread axle and I am wondering if the upgraded equalizer really helps on my setup.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 04-03-2016, 07:37 PM   #2
Don't know about the equalizer, but the wet bolts are a definite advantage. IMO, the equalizers I've seen put an extra torque on the flimsy center link mount when turning. I would go with shocks instead of the equalizer for that fact alone.
Old 04-04-2016, 06:18 PM   #3
I just replaced the shackle bushing with the Never Fail. Have less then 2k on unit including delivery from factory. Discovered the pivot (center bolt)equalizer bushing on both sides was totally gone. Will be watching that in future. Seems the expanded wheel spread on these units may be a weak spot. If the Never Fails, fail I will go to Wet Bolt and see if that helps. I have wet bolts on my Heartland Big Horn and fine there are a pain to get to take grease, always have been since I installed them. I just thought this time I would try the Never Fail, getting older, less labor, we'll see how they work.
George Scott
2015 Salem Hemisphere Lite 272RLIS
2006 Heartland BH 3400/Summer Home
2021 Sabre 37FBT
Scotty is offline   Reply With Quote
Old 04-09-2016, 02:09 PM   #4
2007 WildCat 32QBBS
18CrewDually's Avatar
I just bought and installed a Morryde kit from Amazon for only 89 bucks. It came with bronze bushings, wet bolts, and 1/2" thick side plate shackles. It really tightened everything up nicely.
Search Amazon for MOR/ryde UO12-016 or CLICK HERE FOR LINK
18CrewDually is offline   Reply With Quote
Old 04-09-2016, 06:24 PM   #5
So I have decided to just go with new wet bolts with brass bushings and thicker shackles. Are all of the bolt diameters 9/16"?
Lee and Anne
Old 04-09-2016, 06:34 PM   #6
2007 WildCat 32QBBS
Yes
Old 04-14-2016, 02:18 PM   #7
do the Brass bushing need pressed in?
2015 FR Wildwood X-Lite 262BHXL
2007 F250 4wd CC SB 6.0 Diesel
5LowesOR is offline   Reply With Quote
Old 04-14-2016, 02:24 PM   #8
Did wet bolts and rubber brushed equalizer at the same time. When I took the plastic bushings out they were all worn out. That was after only two short seasons. The bronze bushings just slip in.
donniedu is offline   Reply With Quote
Old 04-14-2016, 02:42 PM   #9
2007 WildCat 32QBBS
No press needed. I use the new bronze bushing to push out the old plastic ones. Apply grease during assembly.
