Old 03-10-2016, 05:33 PM   #31
Not sure what happened to Dan @ TST, maybe he did not get my email.
The alarm goes off on low pressure when the sensor is removed but doesn't sound off if signal is lost. Dan said the time is not 1 hr instead it is 20 minutes when the signal is lost. He also mentioned they will be addressing that issue in their next release.
CraigBean7672 is offline   Reply With Quote
Old 03-10-2016, 06:28 PM   #32
CWSWine's Avatar
I don't think it ought to set off alarm when signal loss but maybe flashing numbers to let you know the signal was loss then after so many cycles/minutes it would warn you.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 03-10-2016, 06:29 PM   #33
CWSWine's Avatar
Originally Posted by D_B Travelers View Post
I have something of the same issue. I have a good digital tire gauge and set all the tires to within a 1/10 of the same pressure before any trip. One of my sensors always tells me the tire is about 3# less than I know it is. Bottom line is it will let me know if there really is a problem with loss of air or a flat, so I am pretty okay with the system. It isn't for NASA, it just keeps track of the air pressure in my RV tires. A couple of pounds difference doesn't change what it does, you will still know if the pressure starts dropping or the temperature is excessive in time to stop. Now that I know about it, I don't worry.
I'm fine with couple of pounds difference and I don't know the tire gauge or TST or both.
Old 03-12-2016, 04:12 AM   #34
07 ThunderRoad's Avatar
If this is how TST handles customer service, I think I will be looking into other systems. I have never used a TPMS in the 20 years I towed a TT, but I am a little bit more concerned about my 5th's tire pressures given the weight of the coach.
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 03-12-2016, 11:47 AM   #35
f5moab's Avatar
Don't knock their customer service, just yet. I had great customer assistance with them when I first got my system and they exchanged the flow through sensors I order, that would not fit, with the regular sensors with NO problems.
And have never had a problem with the system, unlike the other system I had for a few months and threw away.
f5moab is offline   Reply With Quote
Old 03-12-2016, 02:47 PM   #36
D_B Travelers's Avatar
I pulled TT also that belonged to my parents and in-laws also without a TPMS, but they didn't have them way back when. Now I wouldn't think of running without them.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 03-12-2016, 02:50 PM   #37
BandJCarm's Avatar
Trying to comprehend all this.
New Dually doesn't have the built in TMS that the 3/4 ton did. So, I was considering getting the TMS above, with 10 sensors, for truck and trailer when I get it.
BUT........
What happens when I disconnect from the TT and just want to see TPMS data from truck only?????
BandJCarm is online now   Reply With Quote
Old 03-12-2016, 04:34 PM   #38
We had a fabulous customer service experience. I called them at 10:30pm when we were having problems with our sensors. The following day they sent us 2 new sensors. We were treated well on the phone too. We called 770-889-9102.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 03-12-2016, 07:59 PM   #39
I'll keep my TST 507, we buy what we like.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 03-13-2016, 04:19 AM   #40
Witch Doctor's Avatar
BUT........
You should just see blanks where the trailers TST were. As far as being off, it plainly states 1 or 2 degrees plus or minus. I also agree this is not NASA. If your sensor quits reading it will show ZERO. Never timed mine but normally takes around 8 mins to start reading or so. This has been my experience. IMO TST has the best CS. Never had a problem with calling the company. TST is a great company IMO... Also found out that receptionist can answer most questions even taught me to set it up. Call and ask for Mike.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
tire
