Old 03-22-2016, 08:40 AM   #51
D_B Travelers's Avatar
3500 needs the TPMS also
Davidg, I had some initial problems with my TST-507rv dropping the connection with the 4 sensors on the TT. However, I moved the monitor from the windshield to the left rear window of the extended cab TV and have not had a sensor drop on several extended trips. The DW is now the tire monitor and keeps an eye on the readings. Still, with the alarm it isn't really necessary to check it very often, it will certainly let you know if a problem occurs. After upgrading to a 3500HD GMC crew cab dually, I suspect I will need the repeater now, because the distance to the TT wheels just increased about 3'. GMC does not offer TPMS for the 3500 series, I don't know why and I asked, so I am going to add 6 more sensors to the TV wheels before I tow any distance again.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 03-23-2016, 01:06 AM   #52
TST 507
Originally Posted by Davidg View Post
Following this thread as I'm interested in a good quality TPMS system for the camper. The newer tow vehicles have a built in TPMS. Does the TST offer any real advantage over the oem system? I guess the ability to look at temp/pressure in semi-real time? 5 minutes between updates? Geeez,...a lot can happen in 5 minutes! I'm just trying to figure out if I should get a 4 point TPMS or an 8 point. I notice the common package system is a 6 point, so I assume that would be 4 sensors for the camper and 2 for the rear truck tires? I would think that an 8 point system should be available. The biggest thing that grinds my gears is that they sell this system for camping trailers, yet it works poorly "unless" you also drop another $80 on a repeater!!!
That leaves a bitter taste with me. Dang it! Build the system to work correctly for a stinkin camping trailer without gouging the consumer. This marketing system really turns me off. <rant off>
My 507 came with 4 sensors. I only need 4 because our RAM already has sensors in all of the truck tires. It's difficult to put into words just how much peace of mind our monitor provides us while towing. Tonight we just arrived home after a 500 mile tow. Our TST 507 updates each cycle (about every 15 seconds) and will immediately sound the alarm when it decides something is wrong. I found this out when, with my monitor turned on) I decided to add air to one of my tires. The moment I began to unscrew the sensor the alarm sounded.
You won't have to worry about needing a repeater. Tractors with terribly long trailers may need one but for us RVers it is seldom ever needed. We ordered ours directly from the company in Georgia who were less expensive than many Amazon vendors. The amount of damage a blown tire can do compared to spending $250 on the TST 507 make the TST a bargain. It will repay you with the first time it alerts you to a problem.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 03-23-2016, 06:13 AM   #53
Oldbob X2! Peace of mind
Old 03-23-2016, 06:38 AM   #54
Witch Doctor's Avatar
x'2 you are correct .....
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 03-23-2016, 07:13 AM   #55
Too Tall's Avatar
IMO, 300 F is a lot of breaking. If you have those screw on sensors, make sure the valve cores are metal.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-23-2016, 08:42 AM   #56
Blog: RVroadtripper.com
hbillsmith's Avatar
I have 507s. A few comments. Batteries can be bought at Walmart and are easy to change. When I went to a longer 5er I needed the repeater, $50 not 80. Metal stems if you use the 507s with the anti-theft locks, otherwise you can go without.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 03-23-2016, 10:17 AM   #57
CWSWine's Avatar
Originally Posted by gljurczyk View Post
It reads faster then every 5 mins. It will change reading at every revolution. I have a 32' trailer and I find no need at all for a repeater. Mine will pick up 10' from the trailer. I turn it on before I hook-up, so I know this is true. Now if you had 1 40' M/H with a dolly and you wanted to monitor the dolly, I would think that would take a booster only....
From TST website TST manual page number 1 number three states and I quote "3. Sensor transmit Temperature and pressure data every five minutes" It doesn't send data every revolution like you stated above.
But it also states that loss of air it will immediately send a signal.
Here is the link http://tsttruck.com/wp-content/uploa...ser-manual.pdf
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 03-23-2016, 10:22 AM   #58
CWSWine's Avatar
It's not every 15 seconds it's every 5 minutes and if you loose the signal it will display the last setting up to hour after the signal is loss. After you unhook you RV leave you monitor on and take a drive and see what I'm talking about. I have drove 50 miles before the sensor went to zero.
Take a look at page one item number three of the TST manual right on their website and here is the link to the manual ..http://tsttruck.com/wp-content/uploa...ser-manual.pdf
States every 5 minutes.
Old 03-23-2016, 10:54 AM   #59
Pickin' & Campin'
It does say 5 minutes in the manual.
A phone call to TST pointed me to updated info on their website.
Here is what that states...
The sensors transmit tire pressure and tire temperature to the monitor every two minutes unless a gradual tire deflation, rapid tire deflation, or elevated tire temperature event is encountered. In such a circumstance, the reporting is continuous until tire pressure or tire temperature returns to a normal range.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 03-23-2016, 10:58 AM   #60
CWSWine's Avatar
That funny because tech support about a month ago told me that is was 5 minutes for the 507 system. Do you have a link to the info?
Edit ----
I found the reference to 2 minutes and I found another reference on the website to 5 minutes. Looks like they need to update the manual and website to the correct info.
Edit Again. That is a recent change to the sensors and the older models do send every 5 minutes and the newer ones every 2 minutes.
tire
