Old 03-23-2016, 11:25 AM   #61
CWSWine's Avatar
The FAQ on TST webpage and the manual have conflicting information on battery life.
From the FAQ 507 batteries are intended to be changed approximately every 10-12 months then at the bottom of the FAQ it says a year and the manual says every two years.
Here a link to the FAQ FAQ -
Here is a link to the manual on TST site.http://tsttruck.com/wp-content/uploa...ser-manual.pdf
Edit - The difference is that the newer sensors read every 2 minutes with a 10 to 12 months battery life and the older sensors read every 5 minutes and have a 2 year battery life like the manual says.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 03-23-2016, 02:10 PM   #62
f5moab's Avatar
Any way to tell the difference between old and new sensors?
f5moab is offline   Reply With Quote
Old 03-23-2016, 03:28 PM   #63
I have the steel valve stems on the camper but not on the truck, never a problem with the 507
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 03-23-2016, 03:57 PM   #64
Mine continually cycles and it might take 2 minutes, but sure not 5 minutes. Had it for 3 yrs and with both the non flow thru and the flow thru and they both continually cycle.
Old 03-23-2016, 04:05 PM   #65
Mr. Dan's Avatar
With the TST 507 I installed this afternoon, it takes ~22.7 seconds to flash through details of 4 trailer tires. I don't know if it senses new/changed info. that often, but the temp/pressure/tire position info. changed in that period.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 03-23-2016, 04:12 PM   #66
D_B Travelers's Avatar
Mr. Dan, I believe the TST booklet says they report temps and pressures every 2 to 5 minutes depending on whether you have older or newer sending units. I believe this saves battery life by not sending every few seconds. TST also states that any quick change in the tire pressure or temperature is reported to the monitor immediately so you will know something is amiss. Check the link of 5pickers post.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 03-23-2016, 04:20 PM   #67
Mr. Dan's Avatar
That's cool. I wasn't trying to validate a booklet or a web link. I was running a stopwatch on the cycling of display info.
Sent (I think)
Old 03-23-2016, 04:31 PM   #68
Brother Les's Avatar
Originally Posted by CWSWine View Post
That funny because tech support about a month ago told me that is was 5 minutes for the 507 system. Do you have a link to the info?
Edit ----
I found the reference to 2 minutes and I found another reference on the website to 5 minutes. Looks like they need to update the manual and website to the correct info.
Edit Again. That is a recent change to the sensors and the older models do send every 5 minutes and the newer ones every 2 minutes.
CWSWine......
The 507TST can read up to 22 (twenty-two) wheels. 22 wheels may really take 5 minutes. I run 8 tires. 4 on the vehicle and 4 on the trailer. these take less than 2 minutes. If I 'drop' the trailer (push 'MODE and -' at the same time), it takes less than 1 minute to cycle through 4 tires on the truck......
Brother Les
Brother Les is online now   Reply With Quote
Old 03-23-2016, 04:34 PM   #69
Exactly! I didn't know reporting was every 5 minutes until I read these posts. But I did know that if I unscrew one of the sensors so I can add air, the unit screamed almost immediately. That is all I need it to do for me to feel comfortable. I also like that the display cycles quickly through the tires as well. The DW and I wouldn't leave the storage area without them on the TT tires.
Old 03-23-2016, 04:58 PM   #70
Witch Doctor's Avatar
From TST website TST manual page number 1 number three states and I quote "3. Sensor transmit Temperature and pressure data every five minutes" It doesn't send data every revolution like you stated above.
But it also states that loss of air it will immediately send a signal.
Here is the link http://tsttruck.com/wp-content/uploa...ser-manual.pdf
Time the revolutions, it is the best system a comsumer could buy with the best CS from any manufactor. Good luck in your choice....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
tire
