Old 03-24-2016, 04:23 PM   #81
Usually Confused Member
emm-dee's Avatar
Originally Posted by BandJCarm View Post
Stupid question.
What is 'flow through'??
Not a stupid question. I means you do not have to remove the sender unit in order to put air in the tire.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 03-24-2016, 04:27 PM   #82
BandJCarm's Avatar
Duh.
Obvious now.
Thank you.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 03-24-2016, 05:47 PM   #83
At first I thought I would get the flow thru but have limited room on my tire, that is, the flow thru sensors are longer and those would stick out past the tire. When I purchased I called TST and they recommended the RV sensor which is shorter and not a flow thru.
I suppose being able to add air without removing the sensor is convenient but I found that once you get the pressure where you want it and your tires are not leaking I just don't have to add air often and removing the sensor is quick and simple.
I curious when the new update (new color monitor) will be released. Dan @ TST said everyone that already owns a system will be notified of its availability and will get a special upgrade offer.
It is a great system.
CraigBean7672 is offline   Reply With Quote
Old 03-24-2016, 07:32 PM   #84
CWSWine's Avatar
Originally Posted by spock123 View Post
Do you leave your sensors on when you balance your truck tires? I take my sensors off
This is from the TST FAQ
"Each 510 wireless sensor weighs 23 grams, and each 507 sensor weighs 13 grams, both of which are negligible weights; ."
If is was me I won't have them re-balanced if my tires were already on the RV but if I was going to replace the tires I would leave them on during balancing. But that's me...
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 03-24-2016, 07:34 PM   #85
CWSWine's Avatar
I just will add that you can't mix the 510 and 507 sensors. I bought the non flow through for the same reason.
Is the new color monitor going to address the loss signal? That the only complaint I have with the system.
Old 03-25-2016, 09:09 AM   #86
Do you buy your replacement batteries for the 507 at Walmart or where. I looked at Batteries Plus and they were $4.00 apiece. I found batteries at Great RV Products for no name batteries for like a buck apiece and the Everready for two bucks apiece
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 03-25-2016, 09:47 AM   #87
Too Tall's Avatar
Agree, IMO, that is a significant weight and can easily be balanced but I'm anal.
Assuming the tires are balanced prior to adding the sensors, I would weight the sensor on a postage scale (in grams) and add stick on weights to the opposite side of the tire to match the weight of the sensor.
You can get them on line or a motorcycle shop from 7 to 3 grams. They can be cut with snips to match the exact weight you add to one side. Then, as you say when you change tires, have them balance with the sensors in place.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-25-2016, 10:04 AM   #88
"Is the new color monitor going to address the loss signal? That the only complaint I have with the system."
Yep, Dan said the issue is addressed in the new monitor but he did not go into detail on it. So for now, I do not know how it will be addressed, the cost, or time frame.
Old 03-25-2016, 10:29 AM   #89
fireman1317's Avatar
I received my 507 this morning a went through and set it up. I'm only using 4 sensors for my TT only ,but noticed that the screen shows a darkened wheel for my front passenger tire on my TV. Is this a default or does anyone know how to remove it?
2016 Vibe Extreme-Lite 315BHK
2012 F350 CCSRW 6.7l 4x4 LB
Nights camped in 2016: 26
Nights camped in 2017: ?
fireman1317 is offline   Reply With Quote
Old 03-25-2016, 10:35 AM   #90
Mr. Dan's Avatar
Fireman, I got this from a TST Operations Manager: "If you want to clear codes from your monitor follow the same instructions for coding, except as you toggle through and see your codes, press and hold the set button until it beeps and it will clear the code out. Tap the Mode button once you have cleared all of the codes and you should see no tires on your home screen."
To be clear, I wanted to clear the monitor and start over with a new set of sensors -- but if you will get your monitor to display the single unwanted tire and do what's written above, it will clear that unwanted tire. It is not the default... it was an unintended action on your part. No need to ask me how I know!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
tire
