Old 04-11-2016, 04:02 PM   #11
Lvn2tvl's Avatar
You are correct. The internal sensors are accurate for pressure and temp but are more expensive than the external ones. External sensors are just a reference value that does allow monitoring temp but not with the accuracy of the internal ones. I believe the metal stems provide a better indication of tire temp changes but that is very subjective.
2018 Cedar Creek Silverback 29IK
16 Silverado 3500 HD 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
Old 04-11-2016, 04:10 PM   #12
I called TST and was told I didn't need the metal stems
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 04-11-2016, 05:24 PM   #13
Lvn2tvl's Avatar
Sorry but never said required but recommended.
If you ask them about flo-thru vs caps they will tell you the flo-thru are about 1 1/2" long and weren't really designed for trailers. They were originally for dually tires. After reading this forum I ordered them but when I found out how long they are from the factory I changed to the caps and glad I did. Having to take them off is no different than taking the valve cap off to add air.
Bob & Cindy
Old 04-11-2016, 05:56 PM   #14
rsdata's Avatar
I added some sticky foam gasket designed for around doors or windows to stem cold air leakage between the rubber stem and my aluminum wheels, about 1 inch worth. It is fairly thick, maybe 1/2 inch or so. The idea was to prevent the stems from pulling in toward the wheel while running at fast speeds. Have only had them on since last September, but now have over 6000 miles on them and they do work well. I am going to have new metal stems installed when I get new tires and then will not need the foam.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 04-11-2016, 06:07 PM   #15
I bet that is a pretty sight.
Old 04-11-2016, 06:39 PM   #16
rsdata's Avatar
OldCoot
not sure what you expect to see with the foam I suggested, so I ran out in the rain to take a picture as we all know a picture is worth a thousand words... if you cannot see the foam that is because it is hidden by the tire valve...
ID:	104595   Click image for larger version
2014 Shamrock 183
Old 04-11-2016, 06:47 PM   #17
Lvn2tvl's Avatar
MacGyvering sometimes has benefits. Minor potential for balance issues but i can see where it would get you down the road a little farther until you're able to have stems replaced.
Bob & Cindy
Old 04-11-2016, 07:01 PM   #18
(Dry Huunday)
DreiHunde's Avatar
Originally Posted by doc73 View Post
I can attest to the above (have pics if not believed..).. Painted my rims black. One trip South to VA and I can see where the paint was chipped off from them bouncing.. Two dead sensors later after the Florida trip.. no more rubber stems..
Sent from my SAMSUNG-SM-G870A using Tapatalk
Whenever you say you have pics....we want pics!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 04-11-2016, 07:17 PM   #19
Lvn2tvl's Avatar
Pictures, yes please. Thanks
Bob & Cindy
Old 04-11-2016, 07:23 PM   #20
Who Dares, Wins
doc73's Avatar
Ok ok... I opened myself to that one.. I am at work until 7am and the pics are at home on the computer .. Sorry you will need to all Bute your nail in anticipation until about 8 or so..
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
