Old 09-30-2016, 07:15 AM   #41
RedLdr1's Avatar
While at this years FROG Rally I upgraded from the "regular" sensors to the flow thru version. The "regular" sensors were a total pain to remove, especially with the security wrench, on our GTS. The wheel simulators, ie hubcaps, made reaching them awkward to say the least. I prefer the flow thru version for the ease of adding air and removing them while in storage. I wouldn't even consider going back to the "regular" sensors.
Price wise both systems were the same price for six sensors at the Rally. The odd part was it was cheaper to upgrade by buying a whole new system than just buying six sensors. So my next door neighbor got a good deal on my old system for his TT. His valve stems are easy to reach so they work fine on it.
Wayne and Christine
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium
RedLdr1 is offline   Reply With Quote
Old 09-30-2016, 07:24 AM   #42
Does anyone have experience with the internal sensors? Pros/Cons?
Baldicon is offline   Reply With Quote
Old 09-30-2016, 07:34 AM   #43
I took the locks off mine, I am going to put the metal stems on soon when I buy more tires. Just wondering which is best, the high pressure valve stems or the metal valve stems? I had a leaking valve stem on my last trip and the tire man installed a high pressure valve stem.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 09-30-2016, 07:36 AM   #44
The tire man also torqued the lug nuts, I think that was the first time I had seen anyone do that
Old 09-30-2016, 07:40 AM   #45
BamaBob's Avatar
Originally Posted by tom39 View Post
Sorry for resurrecting an old thread but I am in the market to purchase a TPMS and most likely going with the TST 507rv.
But before I do, I was wondering how many people have chosen the FT (flow through) sensors. I am not thinking that this would be something that is needed but the kit with the FT sensors is the same price as the one without, so I thought I would ask
Tom,
I think it depends on your RV. We used the non Flow-Through when we had a 5er (like emm-dee, I was concerned about weight on the rubber valve stem.) Now if you have metal valve stems this issue goes away.
On our Coach we have these massive metal valve stems so I went with the Flow through sensors. I will say this if you choose flow through sensors: make sure they are tightened down when you install them or you will wake up the next day with a flat tire. Don't ask me how I know
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 09-30-2016, 08:05 AM   #46
RedLdr1's Avatar
Fitment seems to be the biggest issue. You need to give TST a call to see if they will work for you. I'd prefer internal but it wouldn't work on our dual rear wheels....
Wayne and Christine
