Old 01-29-2016, 06:40 PM   #1
TST 507 TPMS....A Review
I ordered a 4 channel/tire Truck System Technologies 507 TPMS tire pressure monitoring system from TechnoRV - The RV Technology Specialists ... with the best service! . Great price, free shipping and I had it in two days!
PACKAGING:
Nicely done with lots of extra O rings for when you need to change the batteries in the tire sensors in a year or so.
A cigarette lighter cord and a hard wired cord is included.
A dash board mount and a suction cup window mount is included
Three different installation instructions are included. Seems they kept writing instructions to make it easier. The single sheet that looks like the last iteration was the easiest to follow, along with the TST YouTube video. TechnoRV also has a video on their web site to aid in programming.
SET UP / PROGRAMMING:
I suggest you view the number of YouTube videos available (Google Search) before you do anything. The programming is a bit confusing as it uses a relative few buttons to do multiple functions. If you go slow and be deliberate, it is quite easy. If you can't figure it out, this is why God invented 12 year old grand children!
OPERATION:
I only installed it on my pick up truck. I'll order sensors for the trailer once I'm sure it is accurate and robust enough.
Sensors were programmed and installed on the four tires. I did not replace the rubber valve stems with steel as suggested by others. Reports from others is that the sensors are so light they do not add stress to the valve stems. I agree. Time will tell.
The kit is available with standard (you must remove to add air) and "Flow Through sensors that you can add air without removing the sensor. I went with the NON-Flow Through sensors. I'll have to remove them to add air if needed. Time will tell if this was a good decision. But on my truck the valve stems are about 90 degrees perpendicular to the tire and I had concerns that the longer "Flow Through" sensors might get damaged on curbs or when I take the truck on rough roads.
The system came up and started to send PSI and TEMP immediatly. To test it, I lowered the air pressure and raised it with my compressor and in both cases the reported PSI was extremely accurate and the alarm sounded at low and high PSI parameters I set. The temperature is reading the exact same from each tire (37 degrees in their static state)
The interesting thing is the monitor is sitting here in my office, some 100' from the truck, through a number of walls and an aluminum garage door and it is reading fine. This leads me to believe that it will easily work on a relatively long trailer tow vehicle combination.....If not, an amplifier/repeater is available to boost the signal from the trailer.
All in all I'm very impressed with the quality of construction and performance. The monitor has the feel of a well built cell phone. Nice glass or heavy plastic screen, I can't tell which. Brass antenna connections. Very secure power cord plug/jack.
The tire sensors include anti-theft collars that I chose not to use. Maybe I trust folks too much. We'll see
You can read all about it here:
TST RV Tire Pressure Monitors
Hope this helps if someone is thinking about getting a TPMS
Rbertalotto is offline   Reply With Quote
Old 01-30-2016, 12:10 PM   #2
MrNiceGuy's Avatar
I am planning on purchasing this TPMS system and appreciate you taking the time to write the review. Safe travels.
MrNiceGuy is offline   Reply With Quote
Old 01-30-2016, 12:41 PM   #3
Too old to be too smart
SpringerPop's Avatar
My -507 TST system saved a truck tire last summer when a stem started leaking while we were in a restaurant. Came out to find an alarm condition. We were a thousand miles from home, and towing a trailer.
Long story short, a local tire shop took off the spare the next morning and put the truck's tire back on with a new stem installed in it.
It was a minor inconvenience instead of a desolate roadside stop to put the spare in place of a ruined tire.
Money well-spent for the peace of mind.
Pop
2004 Terry 250RKS, perfect for the two of us and the pups. It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3:73's
SpringerPop is offline   Reply With Quote
Old 01-30-2016, 12:56 PM   #4
acadianbob's Avatar
The 507 system IS an awesome system.
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2016 Surveyor 274BHS
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 01-30-2016, 01:37 PM   #5
DaveSchwartz's Avatar
While it is a good system, the battery is not terribly well sealed by the o-ring. This is probably because the actual housing around the stem does not have much in the way of sealing and moisture can get in that way. I have had two stop working because the battery corroded and shorted out - probably due to the amount of salt used on the roads here (both worked fine again after a new battery and a good cleaning).
I had left them on full time but decided that I'll now take them off at the end of each season and give the battery compartment a thorough cleaning. Since our season is May to October, that will double battery life. Not decided whether I'll remove them if more than a few weeks between trips (which would extend battery life further since they stop sending when at 0psi).
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 01-30-2016, 09:39 PM   #6
I never take my 507 off, 3500 did come O/E.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 01-31-2016, 12:59 PM   #7
Blog: RVroadtripper.com
hbillsmith's Avatar
Had them for 2 years. First year on my 24ft TT, then moved them to the 32ft 5er. Last summer got an alarm for one of the 5er tires and luckily I was one exit away from a Discount Tire store. Turned out to be a loose valve stem. Discount Tire tightened, checked balance and remounted (Free of course, wow).
I started to notice on long hot trips that occasionally, outside interference would cause me to loose signal for the passenger side trailer tires (monitor is mounted far left of driver side). TST recommended their wireless repeater ($50 ouch). I got it and plugged it inside the 5er at the bedroom's nightstand 12v socket(you can just hardwire it to your trailer battery, I like being able to unplug when not towing).
Problem solved, I no longer lose signal. In all fairness, it could have just been the batteries were getting weaker. Only get the repeater if you need it. I think most won't. If you do need it though, it does what it's supposed to.
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover
Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball
LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote
6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard
Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 01-31-2016, 01:15 PM   #8
TST 507
I've had the monitor and one sensor replaced, their warranty is outstanding. one thing I will say is that their digital tire gauge is not accurate and changing batteries very hard to do without damage. Just ordered a 15" Milton truck gauge, simple and made in USA
poppytoymaker is offline   Reply With Quote
Old 01-31-2016, 03:18 PM   #9
Originally Posted by poppytoymaker View Post
.... and changing batteries very hard to do without damage.
I have replaced all my batteries at least twice, and have not found it a problem, but I'm up for a warning.
What kind of damage happened, and do you know how or why?
Pop
Old 01-31-2016, 03:41 PM   #10
Mine should be delivered tomorrow. I went with the smaller shorter sending units because the other would stick out past the tire and a curb strike could happen. The smaller ones are not pass-thru though. I've read many posts on the forum and these guys stand behind their products and offer exemplary cus service.
CraigBean7672 is offline   Reply With Quote
