Old 06-21-2015, 12:56 PM   #1
tst monitor
I have the tst 507 and i need some help.Would like to know if there is any way to clear the monitor so i can start over form scratch.thanks
mojonator is offline   Reply With Quote
Old 06-21-2015, 01:20 PM   #2
Witch Doctor's Avatar
Yes you can, To delete the sensor code press and hold the set button for 3 seconds you will initialize the sensor code to "FFF FFF". But I have an easier way if you set your Parameter setting wrong. I have just went through this. If you have the sensor coded to each wheel, just call TST and they will just tell you to get your monitor and they will tell you what to push and when after they ask your CP of your tire.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 06-21-2015, 01:21 PM   #3
You could contact TST. I'm not aware of any reset procedure, but you could just go back and delete sensor codes one at a time then re-do them. Press the code button for 3 seconds, then use the + or - buttons to move to the sensor code you want to delete, then press the set button for 3 seconds to delete that sensor.
rana is offline   Reply With Quote
Old 06-21-2015, 04:57 PM   #4
Thanks gljurczyk and yarome, will play with it again tomorrow it's 103 way to hot out there.
