Old 06-20-2018, 06:11 PM   #1
Delco Bobby's Avatar
TST sensor stuck
My tires were rotated yesterday. Front to back and back to front. Stayed on same side. SRW motorhome.
I planned to swap the sensors so that they remained in the same position on the vehicle. ie: move the sensor from the rear passenger side to the front passenger side where it was before the rotation.
These are the TST 507 flow thru sensors. Two of the sensors will not unscrew. They are stuck on. I thought about using a penetrating oil or WD40 but donít know if they will damage the sensor bodies.
I did not use the anti-theft set screws.
Seeking suggestions.
Thanks,
Bobby
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 06-20-2018, 06:37 PM   #2
Mr. Dan's Avatar
We assume you loosened the Allen head set screw. Sorry... had to ask.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 0; booked = 14
Old 06-20-2018, 07:52 PM   #3
No problem. I never tightened those screws. Maybe vibration tightened them. I will have someone check. I lost the dexterity to use the little Allen wrench.
2018 Ford F-150
Old 06-20-2018, 08:02 PM   #4
rsdata's Avatar
I would use some spray penetrating oil on the TST stems to get help get them loose...
maybe a T-handle set of these would help with your dexterity from Harbor Freight
I believe the 5/64" is the correct size of the set screw...
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 06-20-2018, 08:26 PM   #5
What material is the threaded part of the sensor made of? My son put aluminum valve caps on his car years ago and they corroded and were very difficult to remove. I canít remember but I may have had to replace a couple of valve stems.
Try some Powerful Blaster penetrating oil.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 06-20-2018, 08:31 PM   #6
Iwannacamp's Avatar
Contact this dude....all questions answered
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 06-20-2018, 10:53 PM   #7
Good idea. There is not enough clearance between the valve and the wheel to use these but I can put them to good use in other situations.
2018 Ford F-150
Old 06-20-2018, 10:56 PM   #8
I was thinking the same thing. I now recall removing one last year to replace a battery and was surprised by the corrosion. Had a difficult time then but only for a minute.
2018 Ford F-150
Old 06-20-2018, 10:57 PM   #9
Attachment 176718
I am hoping he chimes in.
2018 Ford F-150
Old 06-20-2018, 11:44 PM   #10
Rivnut
Rivnut's Avatar
Smile
I got a 2mm hex screw driver at Menards in Indiana, in May, Works well. They had a whole display of the miniture tools, reasonable price.
"Rivnut"
Rivnut is offline   Reply With Quote
