Old 12-15-2015, 10:40 PM   #1
TT GVWR is 7652 lbs; Stock tires only support 7040!
I just got a new FR EVO T2300, the GVWR is listed as 7652 lbs. I happened to look at the tires today and noted that the max each can take is 1760 lbs. 4x1760=7040 lbs. How can that be? I would have thought these things would come with tires that can go beyond the GVWR listed on the sticker
The tires are some no-name brand, ST, width 205.
cali_camper is offline   Reply With Quote
Old 12-15-2015, 10:50 PM   #2
Blackhat6mike's Avatar
Some of that weight is carried on the hitch as tongue weight. Tires are a serious subject on the forum. China comes to mind.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 12-15-2015, 11:13 PM   #3
I guess that's true, there's supposedly 559 lbs tongue weight.
In book, that's somewhat shady math. Where's the margin for error? Will the tires pop if they see anything above 1760 lbs?
I'm already thinking of getting an upgrade before my first trip!
Old 12-16-2015, 01:24 AM   #4
Airdale's Avatar
The tires are squeakers and wont last very long if the trailer is loaded heavy. It's going to be very hard to load and balance it without having a tire or two overloaded. You should go up at least one load range.
Ask FR, "what the heck" over?
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is offline   Reply With Quote
Old 12-16-2015, 01:26 AM   #5
Witch Doctor's Avatar
No, they won't pop, but that is the norm. They come with just enough and get away with it. Probably Trail Express "C" rated. Move up to a "D" rated tire. They are just an accident waiting to happen. We all been through it....
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-16-2015, 12:50 PM   #6
FR figures 10% of the GVWR on the trailer tongue, which brings you down to just under 7,000# with 90% on the tires, and now the tires are not overloaded. Many of us have replaced our original tires moving up a load range: using LRD instead of LRC for instance.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 12-16-2015, 01:04 PM   #7
Dodge Guy's Avatar
Yep, my 11,200lb GVWR Cherokee came with "D" rated tires. that trailers always wallowed and swayed with those tires. when one of the treads separated at 500 miles I upgraded to Carlisle "E" rated tires. the trailer really became easy to tow after that! no more sway from soft sidewalls!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 12-16-2015, 01:21 PM   #8
BiigDaddy's Avatar
Dodgeguy.....I wholeheartedly agree with you on the Carlisle tires. I love ours.
BiigDaddy is offline   Reply With Quote
Old 12-16-2015, 02:05 PM   #9
Grn_Mtns's Avatar
X2 on Carlisle E
Best,
Grn_Mtns
____________________________________
2018 8329 SS Rockwood /260watts solar
Grn_Mtns is offline   Reply With Quote
Old 12-16-2015, 02:32 PM   #10
Camper Less Camping
Cajun Po-Boy's Avatar
If there is one improvement RV manufacturers could make that will be a blessing for everyone...don't cheap out on tire selections!
Sent via Cajun Po-Boy's Tech Gear
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
tire, tires
