Old 09-07-2015, 11:26 AM   #1
TV tire replacement frequency
We made a short trip pulling the 5er this weekend. Approximately 350 mile round trip. My TV is a 2011 F250 Superduty with the original Continental Contritrac tires...now 4 years old. Traveling temp was in the low 90's. About halfway home, one of the rear truck tires must have slipped a belt and began bouncing badly, obviously way out of balance. Since I was on a narrow and long bridge, I had to drive slowly for a couple of miles. Then I pulled over and changed the tire.
The tires have 23000 miles on them. So, I'm trying to decide whether I should replace the entire set? ($1000 +/-) Replace just both rear tires?, ($500 +/-) or replace just the one tire for a spare. )$250 +/-)
Most tire reps say to replace tires at the 6 year mark regardless of tread depth, but in my case, the rear tires are packing a pretty heavy load most of the time. This truck is mostly used for towing. I have an older Tundra I use for daily running around.
So, I thought I would seek the experience and wisdom often offered in this forum. What would you do?
Also, I'm thinking of going with the Michelin LTX MS2 tires
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 09-07-2015, 11:46 AM   #2
Kenny kustom's Avatar
I always replace as a set.
Not to mention, Snow here, 6 months of the year, so traction is key.
2017 Dynamax Isata 4
Old 09-07-2015, 12:05 PM   #3
I usually call around to find a good used tire that will match the other 3.
I'm not sure about big chain tire stores, but the mom and pop places I deal with always have something available for about half price of new.
At times I have run the spare if it matches. (Does anybody rotate all 5 tires like they recommended in the 70s?)
Good luck!
Herdboar3 is offline   Reply With Quote
Old 09-07-2015, 02:03 PM   #4
Airdale's Avatar
Their answer is about the same as other LT tire manufacturers.
What is the service life of a passenger or light truck tire?
Airdale is offline   Reply With Quote
Old 09-07-2015, 08:29 PM   #5
Commercial Member
If you have a belt separation you should
1. contact your local Continental dealer and adjustment of the failed tire and 2. have the rest inspected.
3 You should also file a complaint with NHTSA.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 09-07-2015, 08:44 PM   #6
Iwannacamp's Avatar
Can't go wrong with Michelin. I had a set of those run 80,000 plus...but you could see the air in them. Lol
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 09-07-2015, 08:48 PM   #7
B and B's Avatar
To answer your choice.
I used Michelin LTX on my old F 150 to replace the stock Perrelli's. My New F 250 has them as stock. Looking at the Goshen rally the tire choice seemed to be Michelin LTX.
Smooth running and quiet on the road.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 09-08-2015, 10:10 AM   #8
Well, even with 10/32 of tread depth remaining, both Continental and the dealer says there is no warranty on this tire. So, I've ordered 2 Michelin LTX tires. After shopping around, the best price was from the dealer I purchased the truck from. That surprised me. They even beat Tirerack and SamsClub.
Old 09-08-2015, 10:19 AM   #9
Ford Idaho's Avatar
I replaced the Continental tires that came on my 250 around 30,000, just got tired of needing to slip it in to 4X in the snow just to make it to the HWY.
I replaced the four on the ground with 10 ply Coopers.
http://www.discounttire.com/dtcs/tir...yp=Truck%2FSUV
Traction is way better.......
Old 09-08-2015, 10:47 AM   #10
Did the dealer say the belt slipped? Could you have thrown a balancing weight?
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
replacement, tire
