Old 04-21-2012, 12:51 PM   #101
Great Lakes's Avatar
It's finally time to go camping this year, so I just serviced my hubs for the first time. Thank you Herk, for starting this thread. I was glad to be forewarned on the amount of grease it would take to fill the hubs.
My Mini-Lite is only a year old, but 2 of the rubber axle plugs were cracked through. I ran over to the local RV store & bought 4 new ones. Anyways, hope to hit the road next week.
Tom T.
2011 Rockwood Mini Lite 2104
2011 Silverado 5.3 ~ 4X4
Great Lakes is offline   Reply With Quote
Old 04-21-2012, 02:26 PM   #102
MtnGuy's Avatar
The big chunk of rubber came out of 1 of my plugs this spring , as well as cracks in the other 3. Replaced them all at a couple of dollars each from a local horse and cargo trailer dealer.
Old 03-03-2013, 09:45 AM   #103
As a recent member and being very interested in this subject, I've read all the contributions and comments in this thread, which has been very informative. One thing I'd like to point out is the AL-KO spindle lube design is NOT called Ultralube. The correct name is Ultrulube with a "u" after the r.
Wayne
TexasMac is offline   Reply With Quote
Old 04-10-2013, 10:46 AM   #104
Komodo's Avatar
Originally Posted by herk7769 View Post
With the Ultra-Lube hubs on the Al-Ko axles, the problem is not bearings being packed. The bearings are pre-loaded with grease when installed at the plant. So there is plenty of grease IN the bearing.
The problem comes in that all they are doing after assembly is screwing the Zerk fitting into the end of the axle (in some cases only a thread or two and hand tight) and NOT pumping the axle hub full like they are supposed to.
When you lube from the Zerk for the first time, you need to fill the reservoir between the inner and outer bearings, the space between the trailer side bearing and rear lip seal, push the old grease out of the trailer side bearing, push THAT grease along the outer spindle, and through the tire side bearing and then clean all that mess up.
Since mine had never been done before, it took an entire "large" tube of grease and almost a roll of paper towels.
IMPORTANT TO NOTE: With the easy lube type system, you do NOT need to remove the bearings to repack them. You just put the hand pump on once a month and give a few squirts. When you do your brakes, you should pull the bearings and inspect them for burn marks, wear, and damage. You will need to replace your seals when the bearings come out so make sure you order those too.
I truly appreciated this timely information. I am going to repack my bearings this weekend for the first time; I also have AL-KO Ultrulube that came with my Rookwood HW277. I noticed the pdf, attachments. I will use them as a reference for procedure, truly appreciated, thank you for that.
Do you have any suggestions as to doing my own break inspections as well?
I sure hope this is not a thread hijacking; the thread is about two years old, sorry if it is.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. Wolfgang Riebe
Komodo is offline   Reply With Quote
Old 04-10-2013, 06:16 PM   #105
Herk7769's Avatar
Without knowing your level of skill, I hesitate to say.
Since in PA the camper must be inspected annually, I let them do it.
HAM CALLSIGN - KC3FFW
Old 04-11-2013, 06:38 PM   #106
Komodo's Avatar
As far as I know, there is no such law in Montréal for a tent trailer, I will investigate and let you know. As for my skills, I am not an auto or RV mechanic, so if it goes against your principles, I respect that.
Old 04-12-2013, 10:41 AM   #107
Komodo's Avatar
I contacted Transport Québec, and they said an inspection is only required on RVs or any trailers over 4500 Kilograms or 9921 pounds. My Rookwood HW277 is GVWR 3859 pounds.
Old 04-24-2013, 08:30 AM   #108
bearing repair and lube
Thanks to everyone for the great information.I t was very helpfull.
bear11 is offline   Reply With Quote
Old 04-24-2013, 10:10 PM   #109
Dealer Repack! NOT
That little rubber end cap has cracks that run completely around the dimple in the center. Some of the cracks go all the way through and grease seeps out when the wheel is turning and makes my wheels dirty. It is on the outside so there is no functional problem; it just looks bad.
Been reading this and lot of interesting info here. Thanks to all who have posted. Have my 831 RLBSS, 2011, for some repairs( swung around to tight the back end of tt caught a solid object) so asked dealer to look at dark stains running down the outside, not the backside of the wheel on 2 of the 4 wheels. Its leakage from bearing grease, I believe. Anyway got the estimate at @$220.00, so I emailed them back asking for clarification as to what exactly would be done for $220.00. Dealer replied today saying "Repack bearings, replace seal, clean brakes." Unclear IF they intend to replace all the seals? Will ask for clarification. They also stated seals were not a warranty repair item even tho we bought extended warranty.(Thats another story for another forum I have the AL_KO Ultralube type bearings/hubs.
Anyway thought that to be rather high cost! TT has approx 15K miles.
Wanderer
"All who wander are not lost!"
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 04-24-2013, 10:14 PM   #110
Wayne
Wayne you are exactly correct. Thanks for the post.
axle, bearings
