Old 08-07-2013, 07:15 AM   #161
rattleNsmoke's Avatar
Herk, is there a link to that mod? That sounds like something I may want to look into.
rattleNsmoke is offline   Reply With Quote
Old 08-07-2013, 08:28 AM   #162
Experienced Newbie
Here's what I found after a short Google search
http://www.lci1.com/index.php?option...id=34:products
And this
https://www.google.com/url?sa=t&sour...50310824,d.dmg
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 08-07-2013, 10:35 AM   #163
Windywest's Avatar
The self adjusting brakes might be something I'd change out next year, to be honest I didn't know a mod kit existed, but it sure sounds like a great upgrade. Thanks for posting the info Herk, and Mhartzel for the links, gives me something to ponder before next season.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 04-20-2014, 10:57 AM   #164
PhoneDude 8289's Avatar
Need an opinion!!! Did a brake inspection on our new unit and found two seals leaking grease down the back plate. Cleaned everything up, washed the bearings, repacked by hand and installed new seals. My question is should I run the next year or two with the hand packed bearings or should I grease each wheel thru the ez lube zurks till the grease runs out the front bearing. I'm an old guy from the old school, plan on 5k + miles this season.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 04-20-2014, 01:53 PM   #165
jimh's Avatar
I pumped the grease slowly until it came out the outer bearing. Hand packed mine also. Believe it is the only way to make sure old grease is completely removed. I also Pump a couple squirts in each axle before each pull.
Yes...do both.
jimh is offline   Reply With Quote
Old 06-30-2014, 04:36 PM   #166
John McClain's Avatar
I like lucas heavy dudy equipment and farm grease, drop tem. of 560 deg. . used on are D7 and it work very well on it also
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 08-30-2014, 10:19 AM   #167
I have a 2009 V-Lite TT after 4000 miles a wheel bearing went out had to replace the axle. Had it repaired at a Fleet Pride, Was ok the rest of that year. Next year I packed them myself, and was fine that year. This year I took it to a RV place and had it done, bearing went out after 300 miles. Replaced on the side of the road and replaced the others when I got home. I always keep plenty of grease in them. The last trip I took I left off wheel hubs so I could check the heat. My grease caps kept coming off could that be why my bearings are going so fast.
Granger is offline   Reply With Quote
Old 09-06-2014, 08:46 AM   #168
snapper's Avatar
Beside the obvious, I would replace the dust caps and when you are hooked up and ready, take your trailer to a scale. Make sure its loaded like your going on a trip. Once at the scale weigh the trailer only to make sure you are not overweight. Also it is important that when your going down the road that the trailer is level when hooked up. If it is placing more weight on one axle this will cause the bearings to overheat, which means your overloading that particular axle. Good luck and I hope this helps out.
snapper is offline   Reply With Quote
Old 09-06-2014, 08:56 AM   #169
IMO, failed bearings are usually due to either being too tight or too loose more than overloading or lack of grease. Lack of grease is usually not the root cause of failures.
Old 09-06-2014, 09:08 AM   #170
Thanks for the info I will try all of the above
axle, bearings
