Old 04-02-2015, 11:44 PM   #181
Left Coast
Originally Posted by iluvlcy View Post
Yea I think we will take wheels off, main concern is the cold weather? Thought I had read not to do it when too cold? What is too cold? It would probably be about 40 or 50 degrees when we attempt.
Its more about just being conferrable and being able to take one's time. Nobody want's to work in the cold on an unfamiliar project. The cold weather just freezes zerks sometimes due to moisture in the air during time when not in use...storage.
Old 04-22-2015, 02:23 PM   #182
When to grease axles
We own a 2013 Rockwood Mini Lite camper. Is it recommended to grease the axle at the beginning of every season?
roxie1824 is offline   Reply With Quote
Old 04-22-2015, 05:19 PM   #183
Canadian Member
itat's Avatar
I'd suggest you have the bearings examined and repacked at the start of each season unless you don't put many miles on it. Then you can use the grease zerk and give it a few pumps once in a while throughout the season.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 04-26-2015, 11:33 AM   #184
CanucksonHoliday's Avatar
Please forgive me if the answer has already been posted, but i couldn't find it. Has anyone used Bearing Buddies on the Ultra-lube axles. Would be interested in hearing your opinions regarding their use. Thanks
2007 Durango SLT (Hemi)
2012 Grey Wolf 28bh
Propride 3p
One Old Sailor and His First Mate
CanucksonHoliday is offline   Reply With Quote
Old 04-26-2015, 11:37 AM   #185
Bearing Buddies are good for axles with no brakes, but not for an axle that does have brakes because if you happen to have a leaking seal, it will constantly force grease around the seal and onto the brake shoes.
Old 04-26-2015, 11:44 AM   #186
Makes perfect sense to me, thanks
2012 Grey Wolf 28bh
Propride 3p
Old 04-28-2015, 05:34 PM   #187
Maron
Send a message via Yahoo to Maron
Lubricating the wheel bearings HELP! Oh boy, where do I start? I guess by telling everyone I am as far from being a mechanic as a sofa salesman can get. My Rockwood 8329ss was delivered in January 2014. Since then we have put about 7000 miles on it.
What are the chances I need to lubricate the wheel bearings?
I'm driving from Phoenix to Chicago starting Tomorrow and am scared I will break down.
How often in miles should the bearings be lubed? Any comment will be greatly appreciated.
Maron is offline   Reply With Quote
Old 04-28-2015, 06:28 PM   #188
Herk7769's Avatar
Wheel bearings need to be cleaned and inspected, then repacked every year according to the manual from Dexter, Lippert, and Al-Ko.
If you have "Ultra-Lube axles, you can lube your bearings before every trip by pumping (ALWAYS a hand pump; never air) grease into the Zerk fitting until fresh grease appears, Rotating the wheel as you pump ensures evenly distributed grease.
ID:	75545   Click image for larger version
File Type: pdf 0132-bearing-inspection-maintenance.pdf (112.1 KB, 66 views)
File Type: pdf Bearing Repack and Brake adjustment.pdf (549.5 KB, 69 views)
File Type: pdf Trailer Axle Bearing Pack procedure.pdf (877.6 KB, 63 views)
HAM CALLSIGN - KC3FFW
Old 04-28-2015, 06:53 PM   #189
You would be wise to grease the bearings before you leave. Make sure you follow Herk's advise. Use Lucas Red "N" Tacky grease. You will need at least 2 tubes, better get 3 just in case. TAKE IT SLOW & EASY.
Old 04-28-2015, 10:01 PM   #190
Ret E-9 Anchor-clanker
donanddona's Avatar
Love those pictures. OBTW I replaced all four yesterday. lol
donanddona is offline   Reply With Quote
axle, bearings
