Old 06-07-2015, 08:01 AM   #201
Herk7769's Avatar
Those rear lip seals work great. They will however fail, mostly from 3 reasons:
1) Heat - Overheated bearings can melt the lip seal allowing grease to run out
2) Pneumatic (air pressure) grease gun used on the Zerk fitting or using a "Zerk cleaning tool" to force dirt out of a bad Zerk. Replace or remove and clean a Zerk that won't take grease.
3) Ham fisted mechanic who damages the seal on the axle threads during hub install.
HAM CALLSIGN - KC3FFW
Old 06-07-2015, 08:02 AM   #202
Originally Posted by f5moab View Post
Question. Even if the seal is held in place with an interference fit, doesn't it back up and contact the brakes assembly's backing plate? So it cannot move in that direction? I'm asking, just curious.
Guess I could go check the two I have in my going to the dump pile of metal parts.
No, it should not touch anything except the id of the hub and the spindle itself.
Old 06-07-2015, 08:26 AM   #203
Originally Posted by Iggy View Post
I think we are talking about the grease coming out in the back.
The red is where I think you are talking about the grease coming out.
Also what grease are you using?
That's not good ! You never want to see te grease come out in that red area. Around the zerk fitting is a rubber boot and that is where the old grease should come out.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 06-07-2015, 09:18 AM   #204
f5moab's Avatar
Yep. Just went out and checked my old set, didn't realize that the hold in the backing plate is a lot larger then the outer diameter of the hub.
f5moab is offline   Reply With Quote
Old 07-21-2015, 06:46 PM   #205
opfor2's Avatar
So how do I identify what type of axle's are installed on my FR Sierra Sport ?
2004 Sierra Sport Toy Hauler CSET21SP
opfor2 is offline   Reply With Quote
Old 07-22-2015, 06:04 AM   #206
Should be a white tag on the back side of each axle providing the manufacture and weight capacity. If not, have your VIN handy and call FR they can tell you.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 07-22-2015, 08:04 AM   #207
If all you want to know is the type look under the trailer. If you see leaf springs, like most cars, it is a spring axel. No springs showing then it would be a torsion style axel.
Jim
George Bernard Shaw
Old 09-29-2015, 03:38 PM   #208
opfor2's Avatar
My 2005 Serra Sport came equipped with Hays Axel Inc. T53-3 axels. I can't seem to find any information on them did "Al-Ko" but them out?
Old 09-29-2015, 04:13 PM   #209
Herk7769's Avatar
Have you tried here?
Al-Ko Kober replacement axles, parts.
Old 09-30-2015, 07:45 AM   #210
PhoneDude 8289's Avatar
When storing the RV for an extended time is it best to take the weight off the torsion axels having the swing arm in the unloaded position.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
axle, bearings
