Old 10-06-2015, 12:49 PM   #211
Canadian Member
itat's Avatar
A couple of weeks ago, my step-sister and her husband experienced a bearing failure on a back road with no shoulders. (They have a Crossroads Sunset Trail Reserve TT but probably the same axle manufacturer as FR uses.) Lots of smoke but fortunately no fire. CAA (Canadian version of AAA) was no help - no proper towing units anywhere near them. They limped it to a nearby house and got permission to park it there 'til they could get it properly moved to a brake/bearing service center. They had to replace the entire axle so it was a costly repair.
Suffice it to say that regular bearing service is absolutely necessary.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 06-11-2016, 09:53 AM   #212
23ss ROOster
Wags2237's Avatar
Ultra lube bearing
3 of the 4 zerts took grease fine, pushing out old grease and replacing with new. The 4th zert however, Struggled taking grease. I could barely squeeze the grease gun, a lot of resistance. I was able to get some new grease in and some old grease out before my hand went numb, but I don't think all of the old grease. I noticed the zert was a little loose. I also noticed when I first looked at zert, the old grease around zert seemed drier, just different than the other 3 zerts. Any ideas? Is it likely the bearings are bad? Thanks.
2012 23SS ROO
2014 Ford 4x4 F150 XLT 302A, screw, Ecoboost, 3.73, max tow, off road pkg., 36 gal tank, Ruby Red, tailgate step, Linex spray in, Truxedo bed cover, 30% front tint, Viper remote start, 1000 lbs WDH
Wags2237 is offline   Reply With Quote
Old 06-11-2016, 10:17 AM   #213
clr
Try cleaning the zerk well with a cloth. Gently push on the center ball of the zerk with a pointy object. If either of those does not work, replace the zerk with a new zerk very easy to do they just screw out.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-11-2016, 10:26 AM   #214
Witch Doctor's Avatar
I agree with the post that the Zerk is BAD, go buy 4 new ones at Napa or any other auto store. Your bearing is probably just fine, I have repalced 4 already.. By the way what grease are you using? I recommend highly Lukas Tacky RED 440 heat tested.
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-11-2016, 10:46 AM   #215
Windywest's Avatar
I experienced the same problem with one of my grease zerks when I was injecting grease into the bearings a couple years ago. To make sure it was the zerk, I just removed one from the wheel beside it and screwed it in, it then took grease fine. The old zerk was plugged, so I just threw it away. Grease zerks are about $3 for 5 at any auto parts, Canadian tire, etc.. good to have a couple extra but make sure you get the proper ones.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 06-11-2016, 11:00 AM   #216
23ss ROOster
Wags2237's Avatar
I am using Lucas tacky red
2012 23SS ROO
Old 06-11-2016, 10:29 PM   #217
23ss ROOster
Wags2237's Avatar
New grease zerks did the trick. Thanks for your replies.
2012 23SS ROO
Old 06-12-2016, 02:13 AM   #218
Thanks for letting everyone know...
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-29-2016, 11:31 AM   #219
I have the Ultra Lube axles and I just pull the hub's and repack like a non Ultra Lube axle. I'm just not convinced that I won't blow out the rear seal considering the way grease carries and displaces pressure. Just my 2 cents.
ADVtraveller is offline   Reply With Quote
Old 06-29-2016, 03:14 PM   #220
This can always be a problem, I have never blown the rear seal in 4 years. I change the grease yearly using Lukas tacky RED or Green same grease. I use a hand pump and do it slowly with spinning the wheel. Hand packing is great but you still need to fill that whole cavity. You can buy double lip rear seals at Napa, which are better and stronger. With using different grease you can see when it is all changed, make sure you have a roll of paper towels with you. 2 years ago in Goshen Lippert changed my hubs, they said the grease that is prepack is like water and to change the grease. They know that it isn't good. I just had new tires put on they pulled the hubs checked all the brakes and the adjusted them, there was no grease anywhere in the hub....
Coachmen M/H
Concord
2018 / 300 DSC
axle, bearings
