Old 06-18-2018, 12:01 PM   #251
Originally Posted by Witch Doctor View Post
You did it right, even though there are these complaints, i would say they are few compared to the # that are out there.
I also agree there are few but enough that makes me just do it the old fashioned way.
2017 Coachmen 233RBS
2018 Ford F150 Lariat
"Common sense is not very common"
babock is offline   Reply With Quote
Old 10-17-2018, 06:41 PM   #252
Don't like these easy lube axles. I blew out a seal and didn't know it until I was trying to adjust the brakes and saw grease. It's far safer to just remove the wheel hub and lube them the old fashion way. If you are going to use the easy lube system I suggest you use some locking compound on the seal to hub surface when the seal is installed.
luvbigiron is offline   Reply With Quote
axle, bearings
