Old 02-19-2011, 12:12 PM   #21
Iggy's Avatar
Originally Posted by kalik282 View Post
Iggy,
Be careful with that grease you bought from Walmart. It has a drop point 90 degrees below the minimum spec by AL-KO.
It has a drop point of 350 degrees minimum.
That is what the label says.What do you use?
2012 Georgetown XL - 378TS 66K + miles
Iggy is online now   Reply With Quote
Old 02-19-2011, 12:42 PM   #22
kalik282's Avatar
Iggy,
I prefer a synthetic grease, and usually buy the Valvoline SynPower Synthetic Grease, available at AdvanceAuto ($7.99) and many other places.
Here's a link to the spec sheet for it...
http://www.valvoline.com/pdf/SynPower_Grease.pdf
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 02-19-2011, 02:31 PM   #23
Thumbs up
Here's a diagram of the grease flow:
E-Z Lube Axle
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 02-19-2011, 02:51 PM   #24
Iggy's Avatar
I know 350 degrees may not be what the manuf . wants but lets get realistic.
If my wheel bearings got to 350 degrees they already failed and the grease whould not liquify until 350 F. So I guess if I have grease that doesn't liquify until 450 F isn't going to help much.
If you keep your bearing greased often they should not wear or fail unless it is a manuf defect and nothing is going to stop it.
Don't get me wrong about the grease. I will try any find one with a higher drop point.
I will keep my trailer speed below 100 mph should help. LOL
Old 02-20-2011, 02:01 PM   #25
Iggy's Avatar
Iggy,
Thanks for your input.
Took the grease back and found the stuff I needed.
How is the specs on this one.
Name:	Red Grease 007.jpg
ID:	4589   Click image for larger version
Name:	Red Grease 009.jpg
Old 02-20-2011, 10:31 PM   #26
kalik282's Avatar
Looks good!
John & Nicole
Old 02-21-2011, 11:21 PM   #27
sherdep's Avatar
now you just need to put it in the grease gun and pump the old stuff out LOL
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-22-2011, 06:09 PM   #28
backin15's Avatar
The tube says not to mix different types of grease, how do you know if it is compatable with what is in there already?
backin15 is offline   Reply With Quote
Old 02-22-2011, 07:32 PM   #29
Iggy's Avatar
The color of the original grease from the factory is black and this new stuff is red. It is all Class 2 grease and all you are doing is flushing out the lines and the bearing races until you see all red grease.
Is that what you are looking for?
Old 02-22-2011, 07:38 PM   #30
Herk7769's Avatar
Types of grease is not the same as brands of grease. As long as they meet the specs; color (or brand) does not matter.
HAM CALLSIGN - KC3FFW
axle, bearings
