Old 03-30-2011, 05:02 AM   #41
sherdep's Avatar
Originally Posted by jimh View Post
those rubber end covers? (don't know the proper name for them) are easy to come by and inexpensive. can't beet the price if they just send them to u.
picked up the self adj brake assemblies today; weather will delay installation though.
when u go to replace ur seals, take ur old one with u. they have a couple that are close. (i learned my lesson from buying auto parts. hate to get home and it doesn't match).
they are really just Dust Covers to keep the dirt out of the grease fittings.
According to Al Ko they are called "Grease Caps"
They are doing the same purpose as the Bearing Buddy Dust caps - Keeping the dirt out of the Zirk Fitting - if the Zirk fitting gets dirt in it and you put more grease into the fitting - well now we just pumped grease and dirt right into the bearing - wouldnt be a pretty site to be stuck on the side of the road with a scored bearing or race - when I towed Boats I always carried a spare set of inner and outer bearing's and races as a just in case -
If there is one thing the Marine corp taught me it is to be over prepared then to not be prepared at all.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-04-2011, 10:13 AM   #42
jerr7's Avatar
Send a message via AIM to jerr7
HI all i have a question , im handy and have changed the bearings on my old POP?UP years ago. Now i have a roo23ss 2009,.Please dont think im an idiot yet lol. My axle states its 3700 lb rated is that for one axel or both??.Does anyone know how i can tell if my axel is an ezlube type for the roo23ss.If its not then i have to take apart the wheel and check the bearings and seals and might as well replace all.Last how do i know what size seals and bearings to get is there a certain part Number for this.The complex grease i have.Thanks i hope someone can help
jerry
Roo 23ss 2009
Chevy Silverado 1500 X cab Blk,5.3 V8 3.73
Equalizer Hitch,Garmin GPS,Prodigy Brake Controller
http://community.webshots.com/user/j...host=community
jerr7 is offline   Reply With Quote
Old 04-04-2011, 10:34 AM   #43
jimh's Avatar
The ez lube axels have rubber dust Cover on the end of the metal cover. Remove that cover and u will see a grease cert.
There r other post that have lube procedures on insurting the grease. U will also find manuels. (Think it's this thread).
If u do replace seals or bearings take the old ones with u. There were several seals that were close.
jimh is offline   Reply With Quote
Old 04-04-2011, 11:28 AM   #44
MtnGuy's Avatar
Originally Posted by jerr7 View Post
HI all My axle states its 3700 lb rated is that for one axel or both??
That should be per axle. 3700 lbs. seems like a weird figure though, as many axles are 3500 lbs.
Old 04-04-2011, 01:00 PM   #45
jerr7's Avatar
JIM and MTn guy i appreciate the come back . The Roo23 ss states 3700lbs lol but you know that Forest River lies when comes to their site .I think its alot less but ill use that as a reference lol. i fig somewhere bet 3200-3400 be about right.I looked at the wheel and i see the rubber cap you stated.I gather i can squirt some grease in and see if i can get the grease to flow back out like it states in some of the other replys. I looked into the sites and all the info and i dont think i have to take the wheel off??. Also have used the trailer for about 3000 miles over the 2 1/2 years i had since new.I just dont know how ill be able to tell if the inner seals will be in good shape.I assume if i pump grease in it will eventually come out front lol.I hope 2 tubes to do whole job??I just dont want to have any problems with the rear seals ozing out onto the brake pads Thanks
Roo 23ss 2009
Old 04-04-2011, 01:09 PM   #46
Herk7769's Avatar
If you feel in any way uncomfortable doing this job take it to a shop.
Peace of mind alone is worth the money.
If you have not lubed your hubs AT ALL for 2 1/2 years you may very well need the bearings replaced due to galling of the races or burned rollers. This is not a job for the uninformed since you will need to know by looking at them whether they need to be replaced or not. You will need new seals in any case if you pull the hubs.
The whole idea behind the Ultra-Lube hubs is to lube a few pumps every trip and a flush out through the Zerk fittings every year. You only need to pull the hubs every three years or so to inspect the bearings and change the rear seal.
Without them you would need to pull the hubs and repack the bearings every year.
HAM CALLSIGN - KC3FFW
Old 04-04-2011, 02:21 PM   #47
jimh's Avatar
ok, i'm in the process of repacking the bearings. (i'm also replacing the brakes from the plate out. once i tighten down on the axel nut to resistance, then back off, and repeat all while rotating the wheel, translated into laymens terms, how much do u back off on the nut befoe u insert the pin?
i found 1/2 round but had been backing off 1/4 (from hand tight snug). .001 to .01 doesn't have a lot of meaning to me. how much do u feel comfortable with? i have al ko 6k axels.
Old 04-04-2011, 03:56 PM   #48
KyDan's Avatar
1/4 turn back from -tight- is ok as far as I know.
When I install new bearings I tighten them tight to
help make sure they are seated then loosen to
where you can turn the nut by hand then just tighten the
nut enough to feel resistance in the nut.
Then find the nearest hole for the cotter pin.
It's not real critical. Just slightly firm or just slightly
loose or somewhere in between will work.
If you grab the side of the tire and can feel any play
you've got them just a tad loose
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 04-04-2011, 04:04 PM   #49
jimh's Avatar
thanks. they r free at 1/4 turn and don't feel the side to side play at that point. i want to leave room for expansion without over doing it.
Old 04-05-2011, 02:37 PM   #50
52Dodgeman's Avatar
Good and timely info in this thread. I just started to pre-trip the Flagstaff for the trip to Branson. When I checked my hubs I found that both the right side Zerks were damaged ( look like they were banged against something before the dust cap was installed). I sent Al-KO customer service an email and they are sending me four new zerks. Can't beat that. Once I get the zerks installed I'll pump a little grease in the bearings. The one thing that does dissapoint me is when I measured the center to center distance between the hubs (for a set of wheel chocks I am working on) I found that there is over a half inch difference between the right and left axles. So much for having the axles square to the frame.
Maybe I should just be happy that the bearings were well greased from the factory.
2008 Flagstaff 831FKSS
1997 Ram 2500 4X4 360 Gasser
Wife Candice, two dogs
1957 Dodge D100, 315 Poly
Liberty Hill, TX
52Dodgeman is offline   Reply With Quote
axle, bearings
