Old 04-21-2011, 04:39 PM   #61
jimh's Avatar
0.01 to 0.001 is quiet a range. i backed off 1/4 turn and inserted the pin. hope that was enough.
i'm going to make a short (20 mile) trip next month and check them. right now, there is a little contact with the brakes. drums went on effortlessly. shoes may have to wear into the drum contour.
nut as found was 1/2 round.
hopefully, after 20 miles, will be able to tell if temp rises.
jimh is offline   Reply With Quote
Old 04-21-2011, 04:54 PM   #62
Herk7769's Avatar
WARNING: If your dealer does your bearing service MAKE SURE they are aware of your Ultra-Lube hubs. I just paid to have my bearings repacked and they DID NOT fill the hubs. I had to call them back and find out what grease they put in so I can buy the same stuff.
HAM CALLSIGN - KC3FFW
Old 04-21-2011, 10:08 PM   #63
sherdep's Avatar
Since we are on the subject of how the axles are seated to the frame - I climbed under mine tonight and verifed it looks ok - Here are some pictures of the way mine look - one thing I noticed that they put a washer on the nut side and not the bolt side - the bolt head does appear to be digging into the L Bracket (Frame) - so I may take mine apart and re-bolt it with a flat washer and may drill the top holes and add the grade 8 bolts just for added piece ofmind of knowing it wont happen to my trailer
Name:	P4210257 (Medium).jpg
ID:	5405   Click image for larger version
Name:	P4210258 (Medium).jpg
ID:	5406   Click image for larger version
Name:	P4210259 (Medium).JPG
ID:	5407   Click image for larger version
Name:	P4210260 (Medium).JPG
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-22-2011, 07:07 AM   #64
Herk7769's Avatar
Some info on the Al-Ko Torsion Axles
AL-KO Kober - Rubber Suspension Axles
Old 05-08-2011, 09:28 PM   #65
52Dodgeman's Avatar
Originally Posted by 52Dodgeman View Post
Good and timely info in this thread. I just started to pre-trip the Flagstaff for the trip to Branson. When I checked my hubs I found that both the right side Zerks were damaged ( look like they were banged against something before the dust cap was installed). I sent Al-KO customer service an email and they are sending me four new zerks. Can't beat that. Once I get the zerks installed I'll pump a little grease in the bearings. The one thing that does dissapoint me is when I measured the center to center distance between the hubs (for a set of wheel chocks I am working on) I found that there is over a half inch difference between the right and left axles. So much for having the axles square to the frame.
Maybe I should just be happy that the bearings were well greased from the factory.
Just a follow up. Didn't receive the zerks from Al-Ko before I left for Branson so I bought some and was alble to lube three of the hubs. The fouth damaged zerk would not come out nor take any grease. Went to Branson on a wing and a prayer but made it ok. Upon return home there was a package form Al-Ko with four new zerks. After using every tool in my inventory the last damaged zerk still would not come out. After rounding off and eventually breaking the fitting, I had to drill it out and finally was able to get it off. The problem was the threads into the axle were fouled and who ever installed the zerk kept on cranking until it was "seated". Fortunately I was able to get the old one out without damaging any threads and installed a new one and stopped when it started to bind. Anyway I now have all four bearing well lubricated.
2008 Flagstaff 831FKSS
1997 Ram 2500 4X4 360 Gasser
Wife Candice, two dogs
1957 Dodge D100, 315 Poly
Liberty Hill, TX
52Dodgeman is offline   Reply With Quote
Old 05-10-2011, 09:36 AM   #66
can you buy the same grease that the manufacturer used? In my case, I have the 2011 minilite. How can you find out what they used?
exscream is offline   Reply With Quote
Old 05-10-2011, 10:13 AM   #67
Herk7769's Avatar
Here is what Al-ko said:
Subject: RE: al-kousa.com contact form submission
We recommend a grade 2 automotive with a minimum dropping point of 440 degrees. Any higher dropping point is fine.
Thank You
Old 05-10-2011, 10:59 AM   #68
Thank You
I know what type. I have lots of it in stock from my previous trailer. I need to know what brand etc. You should not mix that stuff. If I use a different grease than what is in my bearings, I have to clean it out completely and that is a mess. I have done that before.
Old 05-11-2011, 08:53 PM   #69
backin15's Avatar
From what I understand you can mix brands, just not types. Al-Ko specifies a lithium complex grease and any lithium complex based grease should be fine, as long as the minimum dropping point is at least 440 degrees.
backin15 is offline   Reply With Quote
Old 05-13-2011, 09:04 AM   #70
Makes sense, thank you!
axle, bearings
