Old 05-16-2011, 09:45 PM   #71
I have a quick question on this subject. I greased mine this past weekend to get ready for an upcoming trip. My question involves the section that I think is called the grease cap. The area between the grease zert and the rubber dust cap. Is this area supposed to be filled with grease of left dry? I was thinking left dry so when I greased mine I wiped most of the grease out of this area which is the area where the old grease comes out when your pumping the new in. Am I right in wiping this area clean or is it supposed to be filled with grease also?
Nights Camped 2011- 12
blake2727 is offline   Reply With Quote
Old 05-17-2011, 08:38 AM   #72
Herk7769's Avatar
Wiped clean (well wiped anyway).
It is "used" grease anyway.
HAM CALLSIGN - KC3FFW
Old 05-17-2011, 08:45 AM   #73
miatared's Avatar
Hey Lou, do I need to spin the wheels to do this "zerking" with fresh grease?
I guess what I am asking is if I can do this while it's parked in my drive way?
Thanks.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 05-17-2011, 12:14 PM   #74
Herk7769's Avatar
Thanks.
I push out the "used" grease sitting in the driveway, but carry the greasgun with me. At the campground, I push a few pumps in before I head home. Purists will jack up each axle and spin the wheel while pumping. This only needs to be done once or twice a year and a full teardown and inspection once a year (per Al-Ko).
Old 05-17-2011, 02:33 PM   #75
DAISY BOYKIN's Avatar
Looks like--------------
Looks like the axle adjustment, greasing bearings, changing zerk fittings is good education for keeping your RV running gear well maintained.
I know when I first found my problem with the axles out of adjustment until now has been an education.
From what I read, a lot of owners know a lot more about their TT, 5ver, Roo, toy hauler ETC from this forum
VERY GOOD FORUM
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 05-17-2011, 02:41 PM   #76
miatared's Avatar
X2 - like having an RV encyclopedia.
Extraordinary.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
Old 05-30-2011, 05:20 PM   #77
backin15's Avatar
I was suprised at how hard it was to find grease with a dropping point above 400 degrees! After several stops I found my grease at NAPA. It is called Sta-Plex by CRC and has a dropping point of 500 degrees. Each axel took about 1/2 a tube.
While I had the tires off the ground I decided to check the brakes. The first one I checked was ok but the other three were badly out of adjustment. They needed between 6 and 10 turns of the adjusting wheel before the shoes made contact. Glad I took the time to check them!
backin15 is offline   Reply With Quote
Old 05-30-2011, 07:42 PM   #78
I used red grease on my previous trailers. Once a year I took the hubs off to inspect the bearings. If the grease was black, that indicated problems. So I did a complete repack with bearing inspection. If the grease still looked nice and red, I pushed a little grease into the bearings with my fingers and reassembled the wheel. This worked well for many years. The grease I am using is Mystic JT-6 by Citco Petroleum Corp. Now on my 2011 traier I have Ultrulube. It does have black grease, so its hard to tell if this is wear or not. After my first repack it will be red again.
exscream is offline   Reply With Quote
Old 05-31-2011, 06:35 AM   #79
As for finding grease, I used Amsoil #2 on three of mine and it has a drop point of 560 or 580 I think. I ran out after three and since I have to order it and wasn't waiting I went to auto zone and got a tube of Lucas red and tacky #2. It has the same drop point as the amsoil and is available at almost any auto store. I used to use it for everything and then I heard so much good stuff about amsoil that I thought I would give them a try but I really don't think they two greases are much different.
Old 06-02-2011, 11:50 AM   #80
I prefer to use AMSOIL Synthetic Multi-Purpose Grease NGLI #2
Does very well on the following tests which are good for bearing life:
Dropping point, (F[C]) - 550 [288]
Four ball wear test (mm scar) - 0.40
Timken load test (lbs) - 50
Water washout (%) - 1.8
2005 Silverado 2500HD Duramax w/Allison (w/EFI Live )
2011 Surveyor 235RKS (customized)
mtl4 is offline   Reply With Quote
axle, bearings
