Old 05-12-2013, 06:41 AM   #121
Herk7769's Avatar
Originally Posted by OldCoot View Post
Not if you consider the equipment required and labor involved. Do it yourself once and I think you will agree that it is not a "Walk in the park". Dirty, somewhat dangerous & time consuming.
In my "round about" way; I was saying the same thing.
No one said owning a camper was going to be cheap...
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-12-2013, 06:44 AM   #122
Originally Posted by herk7769 View Post
...No one said owning a camper was going to be cheap...
Boy, Howdy to that, even if you do 99.9% of the maintenance and mods yourself.
The acquisition of tools, equipment over the years is itself an expense.
Old 05-12-2013, 09:58 AM   #123
Windywest's Avatar
Hi All, this is a very informational forum, and a great topic. We just purchased a used 2011 Flagstaff 26' 5th wheel (8526RLWS) and the wheel hubs look like they have lots of grease in them. I purchased a grease gun and a tube of lithium wheel bearing grease as per specs, but the grease is red. The original grease is a dark, gray colour, so am wondering if it is OK to mix the 2 greases. Any feedback would be appreciated. Thanks Fred in Alberta.
Windywest is offline   Reply With Quote
Old 05-12-2013, 10:26 AM   #124
Herk7769's Avatar
Most likely the dark gray grease is "old used up" red grease.
BTW, I LOVE your camper!
If you have never before greased your hubs since new, you need to have the hubs removed, the bearings and brakes inspected/replaced (if needed), and new axle seals installed. Have the Zerk fittings cleaned or replaced if they won't take grease easily. Ask the shop (if you use one) to make sure the hubs are filled with grease after the bearings are hand packed. They might not want to since it costs them extra for the grease. Ask them also whose grease they used (my Ex-Dealership's shop used some goofy off shore brand that came in a 55 gallon barrel and not available in the USA.) If you don't like their answer, buy a Lithium Complex #2 with a Drop point higher than 446 degrees MINIMUM.
Like:
Mobil Oil............................................... ........................ Mobilgrease HP
Exxon/Standard .................................................. ................. Ronex MP
Kendall Refining Co. .................................................. .........Kendall L-427
Ashland Oil Co. ......................................... Valvoline Val-plex EP Grease
Pennzoil Prod. Co. ....................... Premium Wheel Bearing Grease 707L
THEN, before you go out on a trip, (every time, no kidding):
Pop the rubber insert out of the hub
Connect your HAND PUMPED (no air or battery powered!) grease gun
Pump until the grease that was in the outside bearing becomes the color of the original grease and stop. That pushes the clean grease going in from the rear bearing into the center of the hub and the clean grease from the center of the hub out the outside bearing.
This should only take a few (3 or 4) pumps. Any more than that and you may have a bad axle seal. STOP - this needs to be investigated.
If it is hard to pump; STOP.
Your ZERK is bad, so take it to Autozone and get new ones.
Purists will tell you to jack each wheel and spin while doing this, but if you do not have that ability (easily) it is not worth the extra effort, IMO.
Herk
File Type: pdf 0132-bearing-inspection-maintenance.pdf (112.1 KB, 90 views)
File Type: pdf Bearing Repack and Brake adjustment.pdf (549.5 KB, 108 views)
Old 05-12-2013, 11:22 AM   #125
I place wheel bearing R&R right up there with (1 cord of firewood) lots of tools and equipment required! Youroo!
Old 05-12-2013, 11:49 AM   #126
B47
Lou - I liked the thumbnail showing the grease flow. I have read my manual and knew how the grease flowed, but seeing it was even better.
Old 05-12-2013, 12:01 PM   #127
Herk7769's Avatar
Like always; can't take the credit. "Borrowed" from the Al-Ko site.
Well, now OLD web site. Seems my favorite "explanation graphics" are missing from the new web site...
AL-KO
Old 05-12-2013, 12:10 PM   #128
B47
AL-KO
Well thanks anyway
Old 05-12-2013, 12:12 PM   #129
Herk7769's Avatar
Well thanks anyway
Saved by the Herkbrary...
Old 05-12-2013, 12:15 PM   #130
Herk7769's Avatar
Looked around on the web site,
Whoever designed it needs to be fired.
Misspellings and broken graphics galore!
Old 05-12-2013, 01:42 PM   #131
Informative thread... Thanks to OP, whoever he/she was (Lou, IIRC - it was so many posts ago, lol.)
We have the Ultrulube axles in out new TT. I had read that pumping in grease in twice a year was all you needed and I thought I had a grace period. Does this depend on how many miles you put on? Still don't understand why automotive bearings can go for many years in comparision.
We have alloy wheels and the removable caps seem a bit fragile so I think I will maybe order some spares. Need more spare stuff to stock up on, in addition to a grease gun now...
If and when the time comes, how much do bearings cost? I am thinking I could do a re&re myself. Long time amateur mechanic here (the best ) If I can do something like rebuild the entire front end of a truck, surely replacing the bearings can't be that difficult? Or if you found a cheap source of bearings, maybe it would work to find someone to do the labor only for you? Don't see why I couldn't do a repack myself except for the mess and bother plus it'd probably be at the end of the camping season when it's rainy and cold out.
We have a 2 year warranty. I don't recall seeing anything anywhere saying how often you should re-grease using the Ultrulube zerk fittings. Would failure to periodically re-grease using the Ultrulube feature be a cause for voiding warranty on the bearings if you had a failure? What if you had a bearing repack done by an independent shop at one year. Would that also void the warranty? Same if you did it yourself? I hate the thought of having to pay a dealer their premium plus rates.
Good to know that occasionally the factory does not properly/fully grease up the Ultrulube assembly. I will have to get a grease gun and see what I find. What if you had a bearing repack done by an independent shop at one year?
And I thought buying an RV would be the road to rest and relaxation. Not only do I get to look forward to washing and waxing our TT, I will now have to re-grease periodically. Pffft.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 05-12-2013, 02:30 PM   #132
DDC
DDC's Avatar
Probably outsourced to China or India and while it comes cheaper quality ALWAYS suffers.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-12-2013, 02:42 PM   #133
Herk7769's Avatar
Well, car bearings are now sealed units and run pretty much constantly. Conversely, RV bearings sit for months and then immediately run at 75 MPH reaching temperatures on the sun side of Mercury.
Here is all you need to know about this job.
Bearings, seals, and brakes can be purchased directly from the manufacturer's web sites. Al-Ko axle parts can be bought here: Welcome to AL-KO Kober Corp. - Quality For Life
File Type: pdf 0132-bearing-inspection-maintenance.pdf (112.1 KB, 77 views)
File Type: pdf Bearing Repack and Brake adjustment.pdf (549.5 KB, 243 views)
Old 05-12-2013, 03:07 PM   #134
Wheel bearing pack?
Yes its all relative and I have repacked bearings and replaced seal's on a 2001 Wanderer trailer and it was quite a job, but I had the satisfaction of knowing the work was done, guess I'm sceptical of paying for things such as this that you cannot readily see..not sure that it has been accomplished or not.
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 05-12-2013, 03:30 PM   #135
If you don't trust the dealer to do the job, then by all means go to a shop you can trust, but you will have to probably pay about the same price. It is not a simple job for an inexperienced or ill-equipped person. You are jacking up a much heavier vehicle than the average automobile.
Old 05-15-2013, 02:14 PM   #136
mTn_biKer65's Avatar
Picked up my 2013 Surveyor Select 235RKS last August and with the start of a new season I wanted to make sure the bearings have enough grease so I decided to give this a try. The process went mostly as expected. As expected I cut a couple fingers on the edges of the cap while trying to clean out the used grease. I may devise something better for next time. I used a bottle jack which went well once I was familiar with the extension of the jack. Did both tires then moved to the other side.
Had a WTF moment about half way through when someone decided to resume loading the trailer while I had it up on the bottle jack. Guess I need to be more clear with the work I'm going to be doing.
Down side is I need to remove each tire to access the zerks because of the center cover on my alloy wheels.
Thanks for the info.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 05-15-2013, 02:54 PM   #137
Wanna Be Camper
SaskCampers's Avatar
Got that right, doing wheel bearing is one of my least favourite mechanical things to do.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 05-15-2013, 03:35 PM   #138
Originally Posted by mTn_biKer65 View Post
...Had a WTF moment about half way through when someone decided to resume loading the trailer while I had it up on the bottle jack. Guess I need to be more clear with the work I'm going to be doing...
If you didn't have jack stands under it in addition to the jack, you are courting a major disaster and injuries regardless of whether someone was walking in it. Always let the trailer down on a jack stand or suitable blocking.
Old 05-15-2013, 08:24 PM   #139
Good note which I should've included. I did have jack stands under the frame on each side of the tires. Still nerve rattling to have someone walking around while trying to work on it.
Nights camped
Old 05-15-2013, 08:55 PM   #140
Windywest's Avatar
I plan to use a 6 ton bottle jack, and then let the frame down on to my 6" X 6" wood blocks. Adding grease isn't a big job, but I want to adjust the brakes. My unit wasn't used very much when I bought it, the shower, fireplace, and floor decals were still attached, but I'm not sure how far it was towed. I had a 24' Kodiak bumper hitch before this 5th wheel, and I could lock up the brakes with power level 6. The same power level doesn't seem to have much effect with the Flagstaff, it will grab but not really slow the unit down. I guess I don't know really what to expect, but the 5th wheel is about 2200 lbs heavier, and probably different brakes.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
axle, bearings
