Old 11-02-2015, 10:53 AM   #1
Unbalanced (left-vs-right) RV Trailer Brakes
We have a 2014 Flagstaff Micro Lite Trailer which has only been used three times. Hitched to a new RAM truck with factory brake controller set with gain at +6.0, the left side brake drums get untouchably hot in stop-and-go traffic or on grades, whereas the right side drums remain near ambient temperature. [First trip was pulled with a Tacoma with the same overheating results - problem is not the truck]. Seems to me that the left side brakes are over-working compared to right side - possibly right brakes are not working at all? Dealer has repacked left wheel bearings which hasn't solved problem - didn't think it would anyway, since in light use the left drums do not overheat. They also adjusted the left-side brake shoes.
Any suggestions when I return the trailer to the dealer tomorrow for another attempt to correct this problem (which has occurred since the trailer was new)?
JPKelly48 is offline   Reply With Quote
Old 11-02-2015, 11:10 AM   #2
B and B's Avatar
Hello, have the dealer check with a Amprobe to see if the brakes are all drawing current. The right side might have a wiring problem or the magnets are actually bad. I would check the setup of your brake controller as per Dodge specifications. I know with a Ford once you stop it reduces the amount of voltage applied to prevent overheating. I also know with Ford there is a selection for Electric or Electric/over Hydraulic.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
brakes, trailer
