Old 12-27-2016, 12:54 PM   #1
Underside insulation repair/replace
2010 Wildcat 5er, new to us. Evidently the previous owner had a blow-out which shredded the insulation in the wheel well. I didn't think much about it until we traveled in the rain and noted that the remaining insulation got soaked from wheel splash. I'm sure it can't be good for the water-soaked insulation to sitting against the subflooring - dry rot and all that. Has anyone had success at replacing damaged insulation and getting it sealed/water-proofed?
Thanks for any input.
KJ
2010 Wildcat 28RKBS (purchased March 2016)
Pullrite #2700 Superslider
2006 Dodge Ram 2500 2X2 diesel
2016 - 41 days (2,800 miles)
kejorgensen is offline   Reply With Quote
Old 12-27-2016, 01:42 PM   #2
Ford Idaho's Avatar
I guess you could use some spray on foam insulation and then spray that with some undercoating.
Is there a wheel well liner on the other side?
Old 12-27-2016, 03:21 PM   #3
As I recall (it's at the storage yard now) the fiberglass insulation has some sort of membrane covering the insulation. It's intact on the other side, under the slide-out.
I like your idea of the spray-on foam. If I can't find the product intended for the original use I'll give the foam a try.
Thanks,
KJ
insulation, repair
