01-18-2019, 03:27 PM
Unplugging brake controller when not in use
I had a Prodigy P2 that was easy to disconnect when I would not be towing for a period of time. It stayed in the console in the bag it came with until hooking up to tow. Sadly, it reached end of life.
Replaced with a P3 and had to use the bracket that uses screws to attach the unit to the bracket. The alternate bracket that snap fits does not readily fit under the dash.
How many people disconnect/remove and store their brake controller if not going to tow for say 1 week or more?
I do not like to energize/de-energize electronic things when not necessary.
Thanks in advance
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
01-18-2019, 03:37 PM
never
Fonzie
01-18-2019, 04:03 PM
I have an electronic brake controller in an old truck that's been there for 15 years.
Never been unhooked.
I have an even older controller in a 1985 Bronco... never been unhooked.
Do you regularly unhook your radio and other electronic devices?
I think this is much ado over nothing.
01-18-2019, 04:05 PM
never have
01-18-2019, 04:29 PM
Always Learning
Never even considered it when I had an aftermarket one. This and the prior truck had them installed from the factory.
01-18-2019, 04:47 PM
Never is good advise. I `messed` one up putting it in and out between trips.
01-18-2019, 04:51 PM
Never X10
01-18-2019, 05:19 PM
Coach
Never even considered it.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
01-18-2019, 05:22 PM
I would not worry about it and just leave it connected.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-18-2019, 05:39 PM
Why? Is it in the way or going to get damaged by being left in place?
01-18-2019, 05:48 PM
Xn+1
01-19-2019, 05:19 PM
Forget...
Thanks in advance
You realize that when you unplug it, it loses the settings, right?
Larry
01-19-2019, 05:41 PM
I have had brake controllers in trucks for over 40 years never have I ever disconnected and taken one out when not in use. The current controller has been in the truck for over eight years.
Also I have never had one "go bad" either.....
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
01-19-2019, 08:13 PM
When I used my P3 I only disconnected and removed from truck at the end of the camping season. Could have left connected but with winter weather I felt it was better to remove.
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
01-20-2019, 06:17 AM
Thanks in advance
All GM 3/4 and up pickups come standard with the towing package which includes the brake controller.
Mine has been working flawlessly since 2008.
Im curious how long did that P2 last?
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
01-20-2019, 07:33 AM
Thanks for all the advice. The P2 lasted 16 years.
Retired
01-20-2019, 02:32 PM
Location: Southern IL - across Mississippi from St. Louis
An old fart I know always says, "Sometimes it's best to leave well-enough alone."
01-21-2019, 06:28 AM
never ever had to remove one , no reason for it but I want to ask why remove it?
