Old 10-14-2016, 10:27 PM   #31
CaptnJohn's Avatar
Lets not forget there are probably 10,000 or more ST tires on RVs for every 1 LT. But I don't want to let facts get into anyone's decision making process. If hate to jinx myself but I've been running ST tires since 1976 without even a flat.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 10-15-2016, 08:10 AM   #32
Drive Slow?
CaptnJohn, I'm guessing you drive at or below the speed rating. I always drove the speed limit on the interstates in AZ and NM and always had blowouts or tread separations. When I finally discovered that ST tires were rated for 65 mph, I realized why. I looked for LT tires in 14" tires for my ROO without success. When I saw Load Range D (stock was C) 14" tires rated for 81 mph at eTrailer, I bought enough for two of my trailers. That was last year, and I've gone a complete year without a blowout. I put Passenger car tires on my light bass boat, 3 years ago, and they have held up fine too. I believe it is all about speed and load and temperature rating. When we lived in Tucson, we bought a new Buick which came with a Chevy engine and low temperature rated tires. Go figure. I still carry 2 spares, because I've had two flats the same day several times. P rated tires on trucks on gravel roads don't work well either.
mnoland30 is offline   Reply With Quote
Old 10-15-2016, 08:53 AM   #33
CaptnJohn's Avatar
Mnoland30--- I have always driven the limit and often plus 6-7.. Boat trailer tires were only driven a maximum of 75 miles. I chartered many of them so they were of good size and weight. Trailer tires always replaced in 5 years except for the last ones. The reason the last ones went after only 5500 miles was the SUV was in for an oil change. Told the shop owner I was considering changing to another brand next time. He priced out the 2 brands. After more research I asked if the deal on Carlisle was still good. Bought 5 at $97 minus $20 each for the Trailer Kings. I generally pull between 10,000 and 16,000 miles annually and change every 4 years if the unit is kept that long. At least 95% of those miles are interstate. In the old days only checked pressure in the spring, now before every trip. Just lucky I guess and hope it holds.
2016 F350 diesel
Old 10-15-2016, 09:32 AM   #34
DDC
DDC's Avatar
Originally Posted by sfsgm View Post
You're wrong. I purchased a Cardinal that had, as it turned out, Chinese tires. Somehow there was a problem with ensuring the belts were properly laminated and three of them, no THREE of them blew out on one trip. $2500 damage.
First the Chinese manufactured children's toys with lead paint. Then they built exploding tires. Then they poisoned our pets by putting filler chemical in the pet food. Then they made poisonous drywall. You get my point.....
All of this was not done by China as you are insinuating, it was and is done by the same companies that use to be here but wanted to reduce their costs and increase their profits and for the most parts they have done very well, they then discovered that they would not be subjected to any controls YET so like all business they exploited a situation to make more money, stop blaming a country for the greed of home grown companies.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 10-15-2016, 09:41 AM   #35
CaptnJohn's Avatar
You forget the greed of the US consumer. Most will spend a nickel less than buy Us made. Walmart started that ball rolling until there is nothing left to buy made here. Consumers forced companies there in order to survive.
Old 10-15-2016, 09:43 AM   #36
IMO, broken belts are caused by hitting something and tread separation is faulty construction regardless of brand.
Old 10-15-2016, 09:59 AM   #37
SeaDog's Avatar
Originally Posted by raytwntrvlr View Post
why the RV manufacturers don't use LT tires. And why hasn't everyone changed over to them? Seems like a no brainer automatic. What gives?
Actually it's not a no brainer a few things need to be considered before switching or not. ST tires have stiffer side walls to limit the rocking back and forth while towing, LT have softer side walls to improve ride. ST are designed to be run at max pressure to run cool and wear correctly. LT are only designed to be at max pressure when at max load or you wear out the center of the tire. Just some of the reasons. Each person has to decide what is important to them
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-15-2016, 10:33 AM   #38
ST tire have stiffer side walls to also withstand the short and tighter turns. You can see this when navigating fuel islands and backing into camping spots. Axles and wheels have to withstand this also.
All this bashing of Chinese tires makes me wonder why we generally accept the "American Made" RV's with all their quality issues and then try to spit on the "China bombs". Blow outs usually happen because of road damage, or lack of routine inspections and care. There's blemishes and potential problems with any brand and source of manufacture. We're taking a chance every time we hit the road with our truck and trailer. We all have to make sure everything is up to date, inspected and ready for whatever comes up. Just my 2 cents worth while "knocking on wood".
gfarmcafe is offline   Reply With Quote
Old 10-16-2016, 10:22 PM   #39
You and other ST tire lovers will change your tune when you have a blowout. If you do, I hope you are as lucky as I have been and not cause much damage.
Wish me luck, I'm headed out on a 1800 mile road trip with my LT tires and freshly packed bearings-bearing presses are awesome!
Skyliner is offline   Reply With Quote
Old 10-16-2016, 10:29 PM   #40
CaptnJohn's Avatar
The trip before last was 5760 miles on Trailer Kings. The last was 1100 miles on Carlisle. I hope your LTs treat you as well as my STs have for 42 years.
2016 F350 diesel
tire, tires
