06-19-2016, 03:05 PM
Using RV Brakes manually. Good idea or not??
I was told that it was good idea to "feather" trailer brakes manually when going down steep grade to save tv brakes. Good idea or not!!! Thanks for response!!!
06-19-2016, 03:18 PM
I don't and wouldn't recommend it. The only time I use manual brakes is to set the brake controller and to test the brakes to ensure they work and the plug is seated correctly.
You want your brakes to get worked equally. If you overwork your rear brakes, they may overheat prematurely and not be there for your on a downhill when you really need them.
06-19-2016, 03:27 PM
Only if you like changing brake shoes.
Your TV brakes have much more lining material and on todays vehicles who knows how much more stopping power. Factory Dexter brake shoes only have 5/32" of lining. They are meant to be "supplemental" and not the primary braking system.
Wheover told you that is a dumas.
06-20-2016, 10:53 AM
Always Learning
Personally, I use the engine to slow me down when coming down mountains. I rarely use the brakes.
06-20-2016, 10:56 AM
X2 plus I have an exhaust brake and use. Brakes don't get much use.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
06-20-2016, 12:32 PM
I would agree with most of the posts. However, you may want to use them in a sway event to pull the trailer back. I have only had to do that once on the highway in the past 48 years, but it did save the day when we were broadsided by a rouge gust of strong wind. We did it one other time coming down a steep windy muddy road.
06-20-2016, 12:39 PM
Not a good idea. Let the transmission downshift so your truck will do the work.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
06-20-2016, 12:48 PM
During sever trailer sway OK. Remember your asking those little brakes on that trailer to also slow down your TV.
06-20-2016, 12:56 PM
Bad idea for all the reasons mentioned!
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
06-20-2016, 12:58 PM
X2 We pull with gas so no engine brake but the Ford 6 spd with the max tow transmission avoids much use of brakes.
Floyd & Carolyn
06-20-2016, 01:57 PM
"featherng" the brakes may cause them to overheat and fade, not to good if you realy need them. I would say to test them before you get on a grade to make sure they are working.
06-20-2016, 04:44 PM
Same here rarely use brakes unless extremely steep and then sparingly.
