Originally Posted by ktvaughan
Other than installing steel valve stems on the aluminum wheels (which is also a problem based on blogs),
This may not be the problem, if you use a tr-428 stem.
I'm heading out the door or would look previous posts up for you. You can do an advanced search on my user name and tr-428...and find several posts explaining these clamp in stems.
When I get back, I'll do it if you haven't already,
