Old 04-28-2015, 09:54 PM   #1
Jeepmlc's Avatar
Vibes axle location
Hi everyone I have a question. Can you tell me why the vibe 6500 series trailer axle is so far forward I've been reading articles saying it should be 60-40 the Vibe 6503 is more like 50-50! I have a large storage area and I'd like to use it so I'm going to move the axle back to where it belongs. I'll let you know how it works. 😁
Jeepmlc is offline   Reply With Quote
Old 04-28-2015, 10:17 PM   #2
Greyhawk's Avatar
We have a 2013 Vibe 6501.
Don't know why the engineers located the axle where it is. My Vibe has the fresh water tank in from of the axle. It holds 38 gallons. That adds up to 304 lbs. With a total load capacity of 966 lbs. of water, that leaves 662 lbs. to be distributed elsewhere and may have some bearing on the design.
I'll be interested to hear how it works out.
I remember the first trip that we took. I left the fresh water tank empty because of the weight. Our trip took us down the West Virginia Turnpike. I didn't have a WDH at the time and it got scary more than once. I resolved the issue by purchasing an Equalizer Hitch and started putting some water in the front tank.
I hope it works out for you.
TT = 2013 Vibe 6501
TV = 2015 Nissan Frontier.
Greyhawk is offline   Reply With Quote
Old 04-28-2015, 10:31 PM   #3
Jeepmlc's Avatar
The equalizer hitch was the first thing I purchased before I ever tow my trailer. I knew I was pushing the limits with my jeep as a tow vehicle but it worked great and I did tow mine with the water tank completely full to get enough tongue weight. Of course I had three ice chest in the back compartment along with a small generator and a few tools. My hope is by moving the axle back just a bit I'll be able to tow without adding water and less weight and still have enough tongue weight.
Old 05-25-2015, 06:36 PM   #4
Jeepmlc's Avatar
Added axles
Went ahead and added another axle to my Vibe 6503. What a big difference it makes towing and loading, (so much easier!)
Old 05-25-2015, 06:52 PM   #5
I have a 6501 and the axel is not 50/50 there is more space between the hitch to the axel then to rear. I have towed mine with a minivan and now a ram 1500 it it has always towed great. I have always used a e2 WDH. Not sure about the second axel as it was never designed for that. Not sure how you have the bikes attached but I would not even think about doing that on mine. Frame in the rear is just not strong enough. It sure looks like you should have bought a larger trailer to start with.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-25-2015, 07:24 PM   #6
Jeepmlc's Avatar
Happy Vibe you're probably right! but where's the fun in that!! If you didn't like this mod I'm sure you won't like any of my others. But that's what makes us different.
Old 05-27-2015, 10:19 PM   #7
Sponge1971's Avatar
mod-curious
I'm all ears! list away...
I've been thinking of, at least, moving my 6504 axle back...but, I'm loving your dually mod! (just think how much less stress the tires would be under, load-wise)
I also want to do a bike rack on the back...but it'll require some serious frame beefing. I want to sub-frame from the axle back, and then maybe pin into a top support across the back posts that support the rear wall. Moving the axle back would help keep the pin weight closer to correct.
I want to hang my spare under the nose cone, too.
I know I should have bought a bigger trailer too (32VTSB)...but I don't have a truck and I like how I sometimes 'forget' I have a trailer on...as I nip into a gas station or Tim's. I can imagine being pretty sorry if you don't think about your route when your hauling a 32'er. There is something to be said about maneuverability...
Eric (in Ontario GTA)
2014 Forest River Vibe 6504 (4400# Lippert axle, AxleTek-10-GG self-adjust? drum brakes, Michelin LTX M/S2 P235/75R15-XL-108T) <> 2009 Grand Caravan SXT (4.0L/6spd-62TE), Factory Tow Package, Can-Am RV 'reinforced' OEM ClassIII & 7pin, Michelin Premier A/S 225/65R16-100H) <> Hensley Cub Arrow <> Tekonsha P3 brake controller <> McKesh Mirrors with 8" Convex
Sponge1971 is offline   Reply With Quote
Old 05-27-2015, 10:41 PM   #8
Jeepmlc's Avatar
Sponge Check on my profile and look at the pictures of my modifications. You may see something you like. I did move the axle to the 60/40 location witch was 7'6" from the rear and it was a little heavy on the hitch. I think if I had gone 8' form the back that would have been perfect for the single axle on my model. But I really like how it fells with the dual axle set up. As for my bike rack I did go back the second crossmember in the rear to the back member and added a 3' piece of 2x3 angle iron and bolted to the frame. It holds my tire and my bikes perfectly despite others peoples opinion it's doable And safe.
Old 05-27-2015, 11:46 PM   #9
Sponge1971's Avatar
AWESOME!!
I love the front tank hatch! what a great idea! (what a stoopid idea FR had with those huge cabinet doors) I have got to figure that one out...
storage slide is super cool. I've thought about it, but that damn spare makes things too tight in there...once it's gone, though...
Tell me more about that mattress you have! I'm desperate )-:
Can you add some pics of the frame, for your rack? I agree with you about doable and safe. You just have to do the leverage math and spread it out across the mid-frame. That's why I want to stuff my tire under the nose cone, to shift weight forward. I'm liking your use of the nose con for utilities. I could easily move the tank and battery and pump in there. If I can get the hot water heater in there too, then I could have a full pass-through cargo hold! (I only have a passenger side door, as my utilities take up 3' of driver side cargo hold) and weight distribution would be better, so that I probably wouldn't have to move my axle.
Thanks for the inspiration! now if only I had the time...<sigh>
Old 05-28-2015, 11:17 AM   #10
They must have change the axle placement since I bought my Vibe. I would not be able to move my axle back because I would have to move the awning as well. On mine I have to undo the handle and move the arm up before I bring the awning all the way out otherwise the handle hits the fender.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
axle, cat, location, vibe
