Old 07-11-2019, 03:27 PM   #1
Violent Chugging
I have towed this rig for thousands of miles and have never had this happen. I have a 2019 Ceder Creek 29RE. I tow with a a 2017 Chevy 3500. Anderson Ultimate Hitch. I was braking reasonably hard from 60 mph and the truck and trailer started a back and forth, not side to side, violent chugging. Once I came to a stop for the light and then started up again everything was fine. I tried the trailer brakes manually and they worked smoothly and well. When I stopped and checked everything was tight and torqued correctly including the Pin Box and ball itself. I know about 10 people that tow 5th wheels with this hitch and have talked to about half of them. No problems reported at all. Could it be a fault in the factory Brake Controller or a short in a wire to the brakes causing a pulsating? Ideas?
2019 Cedar Creek 29RE
2017 Silverado Duramax 3500
rocco52 is offline   Reply With Quote
Old 07-11-2019, 03:28 PM   #2
BandJCarm's Avatar
Have you unhitched and inspected the hitch and the king pin?
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-11-2019, 03:46 PM   #3
Coach
How high was your gain dialed up on the controller? Is it possible it pulsates like that to prevent lock up during hard braking? May want to consult the owner's manual for the truck to see if it offers any information. Maybe if you didn't have enough gain to the trailer brakes it was the truck's antilock brakes dealing with stopping the trailer?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-11-2019, 04:29 PM   #4
I did a thorough inspection after un-hitching. Everything tight and solid.
Old 07-11-2019, 04:30 PM   #5
It is set at 4 on a 7 scale. I will checkout the owners manual. Thanks.
Old 07-11-2019, 04:37 PM   #6
BandJCarm's Avatar
Mine is 7 at minimum.
Next time it does this, reach up and pinch the integral brake controller and deploy trailer brakes manually, see if that helps.
FROG AR-0019-242
Old 07-11-2019, 04:37 PM   #7
Iwannacamp's Avatar
I would try to duplicate without the RV...this assumes the 1T has ABS. My GUESS is that the TV was causing the issue.
2017 Puma 297RLSS
Old 07-11-2019, 05:02 PM   #8
A32Deuce's Avatar
Almost sounds like the ABS system on your truck fighting with the non ABS trailer brakes.
A32Deuce is offline   Reply With Quote
Old 07-11-2019, 05:10 PM   #9
I had not thought of that. I have felt ABS brakes under hard braking and they make a fast, noisy vibration that you feel in the brake pedal. I did not notice that but I was pretty busy at the time trying to get the thing stopped. I will try a couple of hard stops with the truck unhitched. Thanks
Old 07-11-2019, 05:23 PM   #10
Iwannacamp's Avatar
In the old old ABS systems...I have known people to disable the things if pulling a heavy trailer. I DO NOT recommend this. The newer vehicles...prolly 95 or later this isn’t a problem...normally. It appears that 10k pushing is more than the abs likes.
2017 Puma 297RLSS
