Old 06-29-2013, 07:40 AM   #11
KyDan's Avatar
Originally Posted by RJHuser View Post
The best way to handle that is when you arrive at your destination, hold the gauge upright, open the vent and let the pressure in the gauge case equalize, then close the vent. This is usually required with large change in elevations, like traveling between the plains and the mountains.
Rick
Good point but I'll add, if the gauge is reading zero when you are ready
to use it, it doesn't need to be manually equalized.
Old 06-29-2013, 08:20 AM   #12
Fulltime family RVer
Originally Posted by OldCoot View Post
Regulators on spigots have a habit of 'walking off'. I mounted mine inside and cut its legs off.
I have mine inside but due to laziness and not concerns about stealing. I don't protect my white hoses (even though I've read the concerns online). I leave my regulator always hooked up to the city water inlet in my wet bay. I even put a quick connect onto it to make hooking up my primary hose easier.
Old 06-29-2013, 08:21 AM   #13
Originally Posted by herk7769 View Post
Well, hush my mouth! Learned something new again.
Well good- you're done for the day. You can go back to bed now! :-)
Old 06-29-2013, 08:40 AM   #14
Denver, CO
garbonz's Avatar
It is a gauge and regulator from RV water filter store, so I will send them a query. This site is awesome, so many helpful posts and so much learning. If it wasn't for the information here, I wouldn't have even known about the importance of a regulator, nor the source of a watts high flow unit.
Thanks...
2017 Fuse 23T
Old 06-29-2013, 08:45 AM   #15
Denver, CO
garbonz's Avatar
Yep, mine is on the inboard end of the hose and my PI surge protector is hardwired. Last night someone walked on my sewer hose which is 25 ft long because of the strange location of the drop on my site. Reminds me that folks just wander around your unit when you are not here and some of the gear is a pretty attractive and easy to grab.
2017 Fuse 23T
Old 06-29-2013, 08:48 AM   #16
Denver, CO
garbonz's Avatar
X2
2017 Fuse 23T
Old 06-29-2013, 02:28 PM   #17
Denver, CO
garbonz's Avatar
Dick's answer (on a Saturday no less). air pocket, no problem. Plus a couple other pieces of input... Great customer service. I highly recommend RVWATERFILTERSTORE.
Robert,
No problem. The air pocket is there to allow for expansion that will bleed out the plug and suck back in when the fluid contracts. This is to prevent actual oil from getting out, which is also why we advise to keep the plug up as much as possible. You have it set up very well, although I would suggest that if you have it set at 45 like may be indicated in the picture, that you move it up to the 60-65 psi range. If the park has it, you will enjoy that much more performance out of your water system. Obviously, if you are too concerned about pressure in the RV, you may choose to leave it at a lower pressure. Your plumbing is rated at 125 psi, so half that should not be an issue. Of course, you may have it already set higher and the pressure at the park is only 45. Anyway, you are good.
2017 Fuse 23T
Old 06-29-2013, 04:29 PM   #18
Glad to see that he responded. Mine is the same way.
Old 06-29-2013, 04:31 PM   #19
And, to add to his customer service- pre-order, he called me on a Sunday night to answer questions. Good stuff!
