06-23-2013, 06:44 PM
weak brakes. Help needed anyone.
Hi,
I bought a 2013 365SAQ sandpiper 5th wheel last summer and from the beginning this trailer has been plagued with weak brakes. The axles are 6000# AL-KO with self adjusting brakes. Controller is maxed out 10 and can barely stop the trailer. Trailer weights 14000lbs.
I adjusted the brake shoes as close as possible to the hub. Still have weak brake.
Truck brake controller is working fine as we tested it on a different 365 with Lippert axle. With this trailer we could not get the controller higher then 3.5 on the controller without the wheel locking up.
I've checked each magnet amps individual and they are all drawing 3.2amps. Ohms are OK as well. Amps loading of all the magnet at the plug is 11amps.
I've removed all the drums to inspect if there was any issues, I could not see anything wrong.
I am in the process of replacing the brakes backing plates to 6000# dexter as I have seen that the magnet is a lot bigger on these.
Dealer is no help as I suspect he thinks I'm imagining the issues. There are some brake, but nothing that could stop me in a emergency. It doesn't help that the dealer is also 800miles away!
Does anyone have any suggestion from replacing all the brakes.
Have anyone else experience issues with AL-KO brakes.
Any suggestion would be greatly appreciated.
06-23-2013, 08:30 PM
If you have 2 6000 lbs axles and a 14000 lbs of trailer(loaded),I'd say the brakes are too light for the trailer. If you are going to put new backing plates and brakes, I'd go with 8000 lbs brakes. What size axles were the Lippert axles. My 3500 lbs AL-KO brakes aren't very good(trailer weighs 6900 lbs),I have to set the controller at 8 to get good brakes-will not lock up the brakes at max setting.
09grizzly1.
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
06-24-2013, 05:03 AM
09grizzly1,
Thanks for the reply. I suspect AL-KO magnets are to small. When I went to the automotive shop and look at other manufacturer of brakes, the magnet were a lot bigger my AL-KO. I'm not sure if it is because of the self adjuster. It seems to need more room.
Were I live in Canada Ontario, no one stocks self adjusting brakes. They tried to order some from dexter and the reply was that this was new technology and they would have to be ordered from the states.
So, I'm wondering if the magnets are too small for this new design and he axle is at it max. That really the only thing I can see.
There is quite a difference in size of magnet between dexter manual and AL-KO self adjusting. See pics. When a load tested the magnet on the dexter brakes 3.6amps and AL-KO 3.2amps. Logic would dictate bigger magnet, more friction on the magnet to ably the brakes?
I'm not try to sink all AL-KO products. I sure they have some good one out there.
06-24-2013, 08:20 PM
I had the same issue with my current 07 Cherokee. The trailer never stopped right. Went through all the systems and everything was OK. I finally just went ahead and replaced all 4 brake magnets. WOW!!! That did it. It took a few miles to burnish the new magnets to the old drums, but once they did the truck and trailer stopped lile never before. I had to back off my controller and turn down the boost on the Prodigy. It's been 3 years now and it still stops like it should.
If you checked all the connections/wiring and brakes as you say you did i would take the chance and replace the magnets. Very glad i did!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
06-25-2013, 04:59 AM
I think its the magnets too. I will be replacing them this week.
thanks
06-29-2013, 12:18 AM
I am having the same problem with my brand new sabre 5th wheel. Brakes are really weak. My dealer is four hours away. I have checked everything. I believe it is the magnets on mine as well. I have the lippert axles. Are you guys replacing the magnets with oem parts or something else?
06-29-2013, 02:39 AM
Incheon, S. Korea
Hmmm... I suspect that this may be the reason why I can't get the brakes to lock on my new Coachmen popup. the backing plates look really cheap.
Me, Julie, Lil' Barry, Faith, and OSD Fang
2012 Coachmen Clipper 126 - Don't even have a TV anymore.
I don't know when we'll be able to go camping again...
06-29-2013, 01:12 PM
Check the total amp draw on your trailer system. Need a good amp meter. Should draw at least 11 to 12 amps. If this is OK, then check the hub for grease leakage. If this is all OK, then you need to contact the axle manufacturer to see if they can recommend anything. Examples: bigger magnet, different brake pads. Most dealer don't have the knowledge when it comes to brakes. They will know the basics, but once they have done all the check and you still find them weak, then the axle guy are the guys to call.
If they are Dexters, then make bigger magnets for there 7K axles. You would have to contact them to see it would be recommended for your axles.
06-29-2013, 02:18 PM
One more thing, check to see if they are correctly adjusted. They may not be adjusted correctly
06-29-2013, 03:03 PM
When I first bought my trailer the brakes did not do much. They are self adjusting and I remembered reading on here about backing up and applying the brakes repeatedly until they were adjusted. I went to a large deserted parking lot and did this and was soon able to lock up the wheels. If I remember correctly one was a little too tight and I ended up backing it off slightly.
06-29-2013, 05:46 PM
Mine are Lippert 6000lbs axles. I have already tried adjusting them and it did nothing. Can I check the total amp draw at the back of the controller via the blue wire.
06-29-2013, 06:18 PM
I check mine between the truck and trailer. Or behind the goose. Most of the time, there is electrical box there were you can tie in your amp meter.
06-29-2013, 06:19 PM
I meant the goose neck.
06-29-2013, 06:25 PM
I just went out and checked. I had 11.3 to 11.5 amps and 13 volts. I have not pulled all the wheels to look ad the pads and seals yet. I have checked all the wiring and grounds.
07-01-2013, 02:13 PM
Well I figured mine out. I pulled one of the hubs and it the brake shoes, magnet and hub is covered in grease. Pulled another one, same thing. Going to dealer to be repaired.
07-01-2013, 06:11 PM
Yes, does EZ-hub are a one shot deal. In the dexter manual, they state that you should only use them we brand new seal and recommended grease. I suspect these seal need to glue to the hub and of good quality. I would not recommend greasing them on a routine basis as you do not know if grease is going into the hub.
A mechanic once told me we listen to the cracking sound. If he it cracking, it means the grease is going pass the seal. Personally, I don't like the EZ-hubs.
I suspect you will need new hubs and brake pads.
07-01-2013, 06:31 PM
My weak brakes were a result of poor connections although I was positive that they were O.K I was wrong.
I agree with Ember. Get a DC clamp on meter and check between connections and where the wires enter the back of the brake mount.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
07-23-2014, 04:41 PM
I am having the exact same problem with my 2013 Sandpiper 35 ROK With the same 6000lb axles. Did you resolve your problem? if so,how?
07-23-2014, 05:46 PM
My brakes had grease on them from the rear seal. I got that fixed but they are still weak. I run my brake controller at full gain. I don't know what else to do.
07-23-2014, 06:02 PM
I had a problem with my old trailer and found there was a broken ground wire at one of the brakes. So I had only 2 of the 4 working what a difference once I figured it out. Wires get corroded and break.
Think about things before you do them make life easier not harder.
