Old 06-28-2013, 10:22 PM   #1
Denver, CO
garbonz's Avatar
weight problem solved (ish)
I have solved (mostly I thin) my weight problem. I was over on GVWR and under on anything else. Which we have discussed ad Nauseum on other posts. SOOO, being the inventive soul that I am, I post the pic below.
Bassically, I took everything that weighted anything and put in a diamond plate box on the back. So now there is NOTHING in the truck and very little in the front of the TT. The rack has a 250 lb capacity excluding the spare.
I will Weigh things on Tuesday, but am sure that my 460 lb overage will be 100 lbs or less.
2017 Fuse 23T
Old 06-28-2013, 10:33 PM   #2
Fulltime family RVer
What will that do to your tongue weight?
ependydad is online now   Reply With Quote
Old 07-02-2013, 05:37 PM   #3
Commercial Member
When you get things weighed be sure to get the weights on each trailer axle so you can calculate individual tire load as you may find you have traded an overweight tow vehicle for over loaded tires.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
