Old 03-20-2012, 05:36 PM   #1
Titleguy's Avatar
Welding to Frame
I am considering having a larger battery tray built to accommodate 2 batteries instead of the 1 that fits in my current tray. I would have this new tray welded to the frame of my trailer (on the tongue just behind the propane tanks where the current tray is now).
I know there are precautions I should take to protect the electrical components while we are welding to the frame. I just don't want to miss anything. Advice?
Titleguy is offline   Reply With Quote
Old 03-20-2012, 06:08 PM   #2
Herk7769's Avatar
I would wait till the camper is out of warranty. Any modifications to the frame (hole drilling or welding) will be reason to provide all sorts of heart ache if you need to file a warranty claim involving the frame.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 03-20-2012, 07:22 PM   #3
Look at the way it was done at the factory and duplicate that to suit your needs. I would do it and not think twice about it. I know I can weld way better than the guys that put my frame together.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 03-20-2012, 11:00 PM   #4
Terier's Avatar
From what I understand it can be an hardship if you welt anything to the frame due to warranty reasons.
I'm trying to add a second battery but there's not enough room for both to be placed side by side. Now we are looking at installing the second battery inside the front storage area and running a connection. Of course the new batteries will be need to be sealed so I wouldn't have to worry about checking the water level.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
Old 03-21-2012, 03:27 AM   #5
flyrotor's Avatar
they also need to be vented so you dont get the offgassing
flyrotor is offline   Reply With Quote
Old 03-21-2012, 10:36 AM   #6
Triguy's Avatar
If you want to avoid modifying the frame, another idea is to bolt a box to the same plate as the current battery box. I saw this awhile ago on RV.Net. Look 1/4 of the way down on this post.
Someone else later in that thread did a different setup. Its half way down.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-30-2012, 10:22 PM   #7
cmcct's Avatar
Here is what I came up with. I bolted it to the existing battery tray, no welding to the frame required.
ID:	11489   Click image for larger version
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
cmcct is offline   Reply With Quote
Old 03-30-2012, 11:02 PM   #8
Drinkin beer on the beach
Rod Johnson's Avatar
I like that bottom one, that sits on top of the frame. I ran into the same problem adding a second battery, there just wasn't enough room between the rails for two Group 29s.
I settled for two Group 27s, but I wouldn't hesitate to weld some angle iron up... Carson said I could weld to the frame and they would still warranty everything, but cutting was a no-no.
Thats actually on my short to-do list maybe this weekend, is to weld up a battery tray and winch mount for the car trailer...
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
