Old 03-06-2014, 08:11 AM   #11
Dave_Monica's Avatar
...or the tires were inflated/set on a cold morning. You may be surprised how much the tire pressure will change with temperature.
Dave
Old 03-06-2014, 08:24 AM   #12
Airdale's Avatar
Vehicle manufacturers set recommended tire pressures. Industry standards - under normal operating conditions - will never recommend using less pressure than what has been set by the vehicle manufacturer. Any tires found 20% below tire placard recommendations are considered to be in a “run flat” condition. Any tires found to be at 50% under tire placard recommendations are considered flat tires.
Here is a useful link.
http://www.safercar.gov/Vehicle+Shop...al+Information
Airdale
p.s. Federal certification labels for RV trailers are found on the LH forward external section of the trailer.
Airdale is offline   Reply With Quote
Old 03-06-2014, 08:37 AM   #13
BombDoc's Avatar
Airdale
Nice Avitar!!
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline   Reply With Quote
Old 03-06-2014, 08:50 AM   #14
chicagoslick
chicagoslick's Avatar
Thanks for all the great information. I have checked the tires with multiple gauges and they all read within 1psi of each other. I only buy good test equipment never the $1 option at the checkout lane (although I bet there probably +/- 2psi accurate). I have checked the tires "cold" so I know they will only gain pressure as the tires heat up while driving. I may call the dealer and see if they inflated them, however I doubt that since these have the "Nitrogen" fill stickers on the side of the TT. This was probably a FR installed option with the upgrade rims and tires. I have taken the trailer for a few drives (~300 miles) to get a good feel for whether the WDH was set correctly and to make sure all is well and have not noticed any issues, tires or otherwise. I will probably continue to think about this, however I am still thinking of reducing to 50psi to be safe.
Again thanks for everyone's thoughts...
Gary, Tonia, Baile, Summer and Otis our Boston T.
Flagstaff 27RLWS Emerald Pkg
2015 Ford F150 King Ranch FX4 Max Tow 3.5EB, 3.55
Equalizer 4 WDH, 1,200 / 12,000Lbs
chicagoslick is offline   Reply With Quote
Old 03-06-2014, 09:03 AM   #15
BigTJohn's Avatar
Check the weight of your trailer, then the max capacity of your tires. If all is well, run them at the sidewall PSI you can't go wrong. I have always used the side wall PSI and never had any problems with tires because of that. Most, if not all will tell you the same. That said, there is a formula for figuring out the exact PSI for certain axle/tire weight loads and what EAC tire PSI should be for that tires weight load - way to complicated if in fact you are not over your tires capacity. If that is the case then bump up a tire spec as long as the axles are within the load spec. And stay at or below the 65 mph limit for ST tires, better fuel mileage and longer tire life.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 03-06-2014, 09:04 AM   #16
dannyabear's Avatar
Mine came with 55# in them and thats where I left them; if you check the load capacity of each tire and weight the camper ready to go, you will find that the tires are carrying very close to their max load. I would not de flate them any.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 03-06-2014, 09:25 AM   #17
Camper Less Camping
Cajun Po-Boy's Avatar
Can't go wrong by setting tire psi according to listed "Max Cold PSI" listed on sidewall...always worked for me with no issues
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 03-06-2014, 09:26 AM   #18
Just thinking out loud here: Is it possible that the delivery guys are inflating them to a higher PSI to allow for faster travel speeds? If the trailer is empty, you can increase tire pressure for increased MPH rating from what I read. When loaded to max tire capacity, you would need to reduce pressure to MAX listed and maintain max speed of 65.
Old 03-06-2014, 09:38 AM   #19
Camper Less Camping
Sounds logical...If I'm a delivery guy, I'm not wanting to mosey along at 65 shipping an rv but as a camper owner...I like my 62mph when traveling
Old 03-06-2014, 09:52 AM   #20
acadianbob's Avatar
Dave
YES! When we leave in April from MN and head south, I leave with 56 lbs of air in my D rated tires. By the time I get to Missouri, I have to start letting out air. (Yes, cold tires).
As an aside, my trailer originally came with C rated tires. My rims are only good for 60 psi. Since I'm way over on capacity, I don't worry about running 56 lbs cold. Just trying to keep everything within tolerances.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
tire, tires
