Old 09-25-2013, 08:02 AM   #11
avolnek's Avatar
Fulton 7-Way to 4-Way or 5-Way Trailer Wiring Adapter With 12V Power Outlet - Overton's
For those of you blowing fuses on the 12v outlets anyone try one of these? Plug it into the 7 pin trailer plug and utilize I believe 20 or 30 amp 12v circuit for charging the camper while in tow?
We use these for filleting fish on the tailgate!
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 09-25-2013, 08:29 AM   #12
dcheatwood's Avatar
I can use the 12v outlet in the basement of my 5er. Can you add one to yours somewhere. Plenty of 12v wires running everywhere, just be careful which one you tap into.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 09-25-2013, 09:18 AM   #13
Brother Les's Avatar
Run a new line and add a higher fuse. If you tap into a wire that is present, you will be popping the fuse in a very short time (do not put a higher fuse in it). The gauge of wire also, will not stand the long run from the power source, you will have a power drop that will not most likely run what you plug into it. You are begging for problems. Run a higher gauge line and bigger fuse.
Brother Les
Old 09-25-2013, 09:41 AM   #14
wmtire's Avatar
I already had several Ryobi batteries for a tool kit I own..so I bought this cordless air compressor (battery not included). it works great and has no problem topping my 50 psi tires off.
Ryobi 18-Volt One Plus Cordless Green Inflator-P731 at The Home Depot
I like the fact that you can set a pressure and the unit turns itself off when reached. I attach it to one tire as I am preparing everything else for the trip. When I hear it click off I go hook it to the next tire and go back to packing...so on, so on.
No power cords, no fuss.
It also works good airing up beach inflatables.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 09-25-2013, 09:59 AM   #15
Triguy's Avatar
Originally Posted by avolnek View Post
Fulton 7-Way to 4-Way or 5-Way Trailer Wiring Adapter With 12V Power Outlet - Overton's For those of you blowing fuses on the 12v outlets anyone try one of these? Plug it into the 7 pin trailer plug and utilize I believe 20 or 30 amp 12v circuit for charging the camper while in tow? We use these for filleting fish on the tailgate!
That's good to know. I'll need to look into this option.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-25-2013, 10:29 AM   #16
wmtire's Avatar
I use the same thing not for an inflator but for a 12 volt impact gun I carry. it works good when having to change a flat on the side of the road. I haven't had to do this with my camper yet, but have used it many times when pulling a tire trailer and had flats/blowouts.
Old 09-25-2013, 11:04 AM   #17
Triguy's Avatar
I ordered it. $21 at Overtons. Couldn't resist another gadget
Scott
2012 Shamrock 233S
Old 09-25-2013, 11:23 AM   #18
CCRVOC
Ramblin Recks's Avatar
I have this 12v compressor, no problems up to 115psi. Quiet with coiled hoses to reach to the 5er tires. Highly recommend it.
Amazon.com: Viair 40047 400P-RV Automatic Portable Compressor Kit: Automotive
Ramblin Recks is offline   Reply With Quote
Old 09-25-2013, 11:24 AM   #19
daydreaming about camping
jeeplj8's Avatar
That is pretty slick.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 09-25-2013, 11:25 AM   #20
jeeplj8's Avatar
going to have to see if Milwaukee makes one...all my cordless tools are red.
