Old 09-25-2013, 11:31 AM   #21
AquaMan's Avatar
I carry a B&D Booster pack with onboard compressor, light, jumper cables, and inverter. Works great.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is online now   Reply With Quote
Old 09-25-2013, 11:34 AM   #22
daydreaming about camping
jeeplj8's Avatar
have you ever used this on a high pressure tire?
My experience with these type compresors is they are only good to around 40 psi. they just don't develop enough pressure to fill up a heavier tire.
My truck runs 65 psi, the trailer 75.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 09-25-2013, 03:36 PM   #23
dcheatwood's Avatar
Originally Posted by avolnek View Post
Fulton 7-Way to 4-Way or 5-Way Trailer Wiring Adapter With 12V Power Outlet - Overton's
For those of you blowing fuses on the 12v outlets anyone try one of these? Plug it into the 7 pin trailer plug and utilize I believe 20 or 30 amp 12v circuit for charging the camper while in tow?
We use these for filleting fish on the tailgate!
Well duh! Had one of those for years. Only used it for my five way boat wire and 12vt q- beam. Never considered it for sir compressor. Thanks.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 09-25-2013, 04:38 PM   #24
Phat Phrog Stunt Crew
awwall's Avatar
I bought this one about a year ago and love it. It produces 120psi and air my 19.5 inch 90psi tires with no problem. It is 110vac.
Senco PC1010 1-Horsepower Peak, 1/2 hp running 1-Gallon Compressor - Amazon.com
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 09-25-2013, 05:14 PM   #25
Fulltime family RVer
I tried something like this from Costco/BJs. My first problem was that I couldn't use it for the inner dual tire on the truck. The second problem was jeep said- it just couldn't push the tire pressure needed for the tires.
I ended up buying this:
Porter-Cable 3.5-Gal. 135 psi Pancake Compressor-PCFP02003 at The Home Depot
I throw it into the basement of the fiver. I'm SOL if I'm on the road and need it, but it works when I'm at home and at campgrounds w/ electricity.
I'm jealous of the Viair onboard systems.
ependydad is online now   Reply With Quote
Old 09-25-2013, 06:17 PM   #26
AquaMan's Avatar
My tires run 80psi on truck and trailer. Have no problem bringing either up to pressure. Would not want to fill entire tire though.
Old 09-26-2013, 08:52 AM   #27
flyguy's Avatar
I did a post with pictures of what I did on my Wildcat to provide 12v exterior outlets so I could use my 12v air compressor to inflate tires and use my 12v impact wrench to remove them when changing them on the road. Here's a link to that post: http://www.wildcatcamperforum.com/t5101-12v-exterior-outlets
2003 Wildcat 27RL
2008 Toyota Tundra 5.7L Crewmax
Superglide 3100 Autoslider Hitch
Timbren SES
Prodigy P3 brake controller
flyguy is offline   Reply With Quote
Old 09-26-2013, 08:54 AM   #28
jeeplj8's Avatar
That is good to know. Perhaps this unit is a bit heavier duty than the ones I have seen/tried in the past.
Old 09-26-2013, 10:48 AM   #29
Good stuff. Yours is definitely heavier duty than mine, then. Mine struggled with 65-70psi in my truck tires.
But, I also just re-read the OP's subject line and they're only looking for 50psi. Seems like it could be a decent choice for them.
Old 11-28-2013, 07:52 PM   #30
Viair 400P 12volt heavy duty air comp. power cord to connect to battery'
Gee Whiz is offline   Reply With Quote
