06-12-2012, 01:28 AM
What jack do I use?
I have a 2013 28ft Wildwood x-lite. If I need to jack it up to change a tire, adjust brakes, check wheel bearing, etc., what kind of jack can I use? Is a standard scissor auto jack ok? Approx. dry weight 5900lbs. New to the trailer camping thing. Thanks for any help.
06-12-2012, 06:35 AM
"On the road again"
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
06-12-2012, 07:06 AM
The jack from your TV will not work. You will need to get a bottle jack or a large floor jack.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
06-12-2012, 07:22 AM
Instead of using the dry weight, I like to carry a bottle jack that is rated at twice (or more) the trailer's GVWR. My trailer is slightly less than 3 tons so I carry a 6-ton jack.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
06-12-2012, 07:37 AM
When I bought my 21rr and was on the way home from the dealer and a tire blew, the only jack I had was the one that came with my F150. It worked perfectly and so did the F150 lug wrench.
06-12-2012, 07:51 AM
When hooked-up, I use one of those tire change ramps that I can just pull or back-up on with the good tire on one side, and change the other. When parked somewhere, I just use the jack from my Ram TV. Works perfectly. If parked in my driveway, I have a 3.5 ton floor jack that I roll out of the garage to lift the TT easily.
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
06-12-2012, 08:33 AM
Why not? My TVs jack is a bottle/screw type jack. I'm not sure what the jack is rated, but my TV is heavier than my TT (F-250 4x4 Crew Cab Diesel vs 26TBSS), so I assume it's got the strength to lift it. Never had to use it in an emergency, but I have tested that it'll lift a tire off the ground if it needed to. at home I use a 3-ton floor jack and jack stands, but my TV's bottle jack is good enough for a road side emergency.
It's like this one...
'01 F-250 PSD CC 4x4 SB
'08 Wildwood LE 26TBSS
State's we've RVed in
06-12-2012, 08:35 AM
For less than thirty bucks you can get a 10 ton hydraulic jack from Harbor Freight what will work perfectly. Less cranking and probably faster too. Don't forget to get a 1/2 inch breaker bar and the correct socket too for your wheels.
06-12-2012, 09:53 AM
X-2 on the 1/2" breaker and extension.... Check your sockets and lug wrench to make sure they fit alum. wheels... may need a thin walled socket.
I like to carry my torque wrench as well.
06-12-2012, 05:20 PM
i have a 1/2 inch dewalt 18 volt impact wrench, maks short work of lug nuts. i do like te idea of pulling good tire up on ramp to change flat never thought of it thanks.
06-12-2012, 05:48 PM
Another rat in the race
I use the lynx blocks myself. Some people say that it weakens the spring on the loaded tire. But I don't lift it until I have everything there and ready and lugs are cracked loose so 5 min max I wouldn't recommend eating lunch in the middle of the job anyway.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
06-12-2012, 05:51 PM
Some of those cheap 10ton jacks barely lift the front of my 6200lb truck. So I think the jack for changing the tire on the truck will work for my 5000lb TT also, but haven't tried it.
06-12-2012, 09:55 PM
Purchased at Walmart.
Ordered one of these from Amazon last week.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
06-18-2012, 05:29 PM
Jiffy Jack - for changing tires and whatever.
We carry a Jiffy Jack (see it at valleyvet.com). Easy to use. Loosen lug nuts of flat , drive up onto Jiffy Jack with non flat tire. We tow a 30ft 2607s Rockwood and have used it. Used it on my horse trailer too(which is why I had one to begin with). We got aluminum for about $50.00. You don't have to worry about where to put the jack on your trailer and you don't have to crank a jack to get your tire off the ground. Check it out. DJT
06-18-2012, 07:10 PM
Last week when I had a flat on my trailer called the auto club and when he showed up he had brought a wimpy 2 ton floor jack wouldn't lift trailer high enough. I had put a jack that somebody had gave me from a one ton dually like mine in my tool box for emergency I put it at axle between U bolt which by the way fit perfectly between U blots and cranked up trailer just fine in fact was easier than his floor Jack. He also used a cheapo air inpact to remove lugs two which he couldnot budge I pulled out my torque wrench and had it loose in no time. He put spare on and used same inpact to put it on after which I torqued lated as most were not tight at all. Boy next time I will replace my own tire and be on my way alot sooner than waiting for 1 hour for this guy to just show up and I will feel alot safer by doing it myself.....
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
06-18-2012, 07:46 PM
I have a 12 ton bottle jack and 2 three ton bottle jacks.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
