Old 07-19-2015, 05:32 PM   #11
bikendan's Avatar
if you bought from RVW, send the co-owner Dave Durnell a PM.
he's a member here and has an open invitation for his customers to PM with issues.
he has a great rep here on the Forum.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-20-2015, 03:53 AM   #12
Thanks. I will for sure do that.
chrosw726 is offline   Reply With Quote
Old 07-20-2015, 04:00 PM   #13
I got some pictures but not sure if I'm doing this right so I will just test it here to see.
Old 07-20-2015, 04:27 PM   #14
Pictures
Ok, so I took some pictures. What do you guys think?
ID:	83485   Click image for larger version
ID:	83486   Click image for larger version
ID:	83487   Click image for larger version
ID:	83488   Click image for larger version
ID:	83490   Click image for larger version
ID:	83491   Click image for larger version
ID:	83492   Click image for larger version
Old 07-21-2015, 01:27 AM   #15
Axle Identification
Like Scotty says, there should be a silver tag on each axle, usually midway across the tube and on the backside so the road rash doesn't take IT off. What I have done, is take pictures of all that ID, including the magnets etc when I pulled my wheels to pack bearings. I have all the pics and numbers on my phone in case I get stuck on the road and need help. Hope this helps
Filterman is offline   Reply With Quote
Old 07-21-2015, 02:03 AM   #16
Just a member
kandl's Avatar
The dust cap looks to be secure but there appears to be a lot of excess grease along the lip of the cap. If some of that grease was external (sloppy work) to the cap, it would surely find its way out along the radius of the wheel.
Btw, and assuming the rig is equipped with Dexter axles, you have the E-Z Lube axles. That threaded hole in the center of the axle is the giveaway. Go fetch some zerk/grease fittings and you'll be able grease the bearings without having to disassemble the unit. The feature that includes the rubber access plug on the dust cover is nice but not necessary. I have the plugs but remove the dust cover so that I'm better able to view the grease pushing through the outer bearing.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 07-21-2015, 02:18 AM   #17
Crockett's Avatar
well, those dust covers wont work with the zerks. interesting that the mfg ditched the zerks. question...if you add zerks, how will you know that the grease you add is compatible with the existing grease? better to just do a bearing pack and ditch the already known to be funky oem grease...
Crockett is offline   Reply With Quote
Old 07-21-2015, 02:42 AM   #18
Just a member
kandl's Avatar
Not necessarily. Some do. May be tight but some will fit. Measure twice...
By pumping in grease that is recommended by the axle's manufacturer.
Old 07-21-2015, 05:01 AM   #19
Ah yeah I was going to look for that. That is a very good idea about the pictures. I will take your advice and do the same. Thanks.
Old 07-21-2015, 05:09 AM   #20
I don't think the grease build up on the outside of the cup housing was that bad at the beginning of my trip. Seems like it built up more the longer I drove it. But I could just not noticed it before. Seems like the wheel is more greasy on side then other. Maybe the dirty side of the cup was always out of my view? I am happy to hear that it is an EZ lube type an axel. Thanks for the great info.
axle, wildwood
