11-14-2019, 04:08 PM
#41
Had to make a top plate to place over the top of jack. Also have a base plate to keep jack from sinking into ground. Picks up both tires using the pictured location. Worked great when I put on the new tires.
11-14-2019, 04:14 PM
#42
I also just use the Jack for Ram 3500, lifts my Cedar Creek 5th with no problem.
Kathy & Larry
2016 Cedar Creek SilverBack
2014 Ram 3500 Big Horn - Diesel 6-speed
11-14-2019, 04:18 PM
#43
Jack
I use the Anderson drive on jack. Can also be used for tongue block. Prevents bending an axle or crossmember support on Dexter Torsion axles. Many of the Ultra Lights have no good place to put a bottle jack. Check your trailer.
11-14-2019, 04:24 PM
#44
Trailer Aid
I have used the trailer aid jack, very easy to use and they are safe.
11-14-2019, 04:32 PM
#45
I can lift at the frame, above the axles, but that's like 22 inches on my trailer. I am going to order the Trailer Aid Plus today, and if I need a little additional lift I will break out the screw jack from my TV.
I really appreciate everyone's input!
btw - also ordered some safety triangles, based on TitanMike's suggestion.
11-14-2019, 08:37 PM
#46
I use a cut off piece of wood that could have been part of a railroad tie. Just drive onto it with the good tire and the other tire lifts. Nice and stable!
11-15-2019, 10:50 AM
#47
I haven't heard anyone using a angled block of wood to simply pull your trailer up onto using the good tire lifting the flat tire up enough to change it. Does anyone do this?
11-15-2019, 11:44 AM
#48
Always Learning
That's essentially what the Trailer Aid device is that someone shared above.
It works. Some people are concerned with the extra/over load on the good tire and wonder if it'll cause problems.
11-15-2019, 12:08 PM
#49
When driving down the road, a tire will see double its load many times so not really a concern since when jacking the trailer up, its just a static load. When one gets a flat and one tire is carrying twice the dynamic load while trying to move over to the side of the road is the worst time for that other tire.
11-21-2019, 07:32 PM
#50
We have this one. 3 ton, lightweight aluminum. It's cable locked in the bed of the truck.
11-21-2019, 07:39 PM
#51
Big red floor jack
I use a portable Big Red floor jack, I also rent so I don’t need the headache of a renter not knowing how to use their own vehicle jack. Also if the tongue jack fails you have a means to get the trailer up.
Originally Posted by Qwkynuf
Working on outfitting my new Micro Lite 21DS, after having been without a trailer for several years.
I'm thinking that I would like to pick up a bottle jack to carry around, since it uses less space than a floor jack, But it also doesn't look like the trailer has a bunch of good contact points - and the bottle jacks don't have a ton of surface area.
I'm towing with an open bed pickup, so lots of space, but not lots of lockable space.
What do most people do for these kinds of rigs?
Thanks!
Qwkynuf
11-21-2019, 07:50 PM
#52
Dual or single axle
If your tt has dual axles check out the anderson rapid jack, works slick, light weight, and can double for leveling your rig in a pinch if you need it to. I use the anderson levelers as well but did see a fiver owner use his rapid jack a couple of months ago while on the coast.
11-21-2019, 08:18 PM
#53
I seem to have torsion axles, so it's really looking like a challenge to even find a place to jack on them if needed.
Appreciate the input though!
I have torsion axles on my Rockwood 5'R and have no problem getting the bottle jack on the frame, which is where you are supposed to jack anyway.
2010 Rockwood 8280WS Fifth Wheel
2013 F350 Crew Cab SRW, Standard Bed PS Diesel
Reese Airborne Pin Box, Reese 16K Manual Slider.
Camped 36 Days in 2012, 23 Days in 2013, 35 Days in 2014, 30 Days in 2015, 46 Days in 2016, 5 days in 2017.
11-21-2019, 08:47 PM
#54
Harbor Feight Aluminum 2 ton Jack. Only used it to fix a flat on the wifes van.
11-21-2019, 09:35 PM
#55
I have (2) 3 ton bottle jacks and a 2 ton floor jack. All 3 fit in a plastic tote with my other recovery gear
11-21-2019, 10:02 PM
#56
I have convinced myself, by looking at it, not by trying it, that the jack in my 2018 Chevy will work on my TT. I hope I am correct.
2018 Shadow Cruiser 265RLS
2018 Chevy Silverado 1500 with 5.3 max tow package
Shiawassee County, Michigan
11-21-2019, 10:15 PM
#57
The best purchase I ever made. Camco Trailer-Aid "Plus" Tandem Tire Changing Ramp. I bought mine at Walmart for about $36. It will hold up to 15,000 lbs and raises the wheel 5 1/2 inches. I had to have new tire valve stems installed and the guys at the tire store used it to raise the trailer. They had never seen one and loved it. The owner said he was going to order one to have on his service truck.
2018 Rockwood Mini Lite 2507S
2015 Chevrolet Silverado 2500HD 6.0 L
11-21-2019, 10:35 PM
#58
I Use Trailer Aid Plus
I frequently tow my 22 foot inTech race trailer with my Sunseeker Class C motorhome. I have a Trailer Aid Plus that I purchased on Amazon. It holds up to 15,000 pounds, and has a 5.5 inch lift. My trailer has Dexter Torflex axles and the one time I had to use it, it worked great; quick, easy and safe. I also carry a 1/2 inch Makita 18v cordless impact that makes a tire change much easier.
Since I am towing a trailer with a Class C, weight is always an issue. I try to avoid floor jacks, wooden blocks, etc. The Trailer Aid is very light. Note, the picture attached is from Amazon, but it demonstrates how it works.
2018 Forest River Sunseeker 3270 Class C Motorhome
2019 Jeep Wrangler Sport S Toad
2018 inTech 22-foot Enclosed Aluminum Race Car Trailer
11-21-2019, 11:00 PM
#59
I carry a small 4 ton bottle jack and some pieces of 2x8 to place under the jack. My springs are underneath the axle so I have a got point to place the jack. By jacking the axle your not lifting the whole trailer, so you can get away with a small jack. I know all about the possibility of bending the axle, won't happen if you jack at the spring attachment.
11-21-2019, 11:19 PM
#60
Novice Travel Trailer Guy
Originally Posted by Telstar
I carry a 3 ton bottle jack, but also carry this which makes it much easier to change a tire.
2x for this option. Quick.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
